Timing roller 180 out
Michael Davis
First Name: Michael
Last Name: Davis
Post by Michael Davis » Wed Aug 21, 2019 2:24 pm
Hi Bought a 22 with new engine never has been fired. I have #1 just pass TDC piston is about 1/8 down on combustion stroke. Roller pointing at # 4 not # 1 I know on a distributor type engine if a little off move the plug wires. What could be causing this? Any information will be helpful
Thanks Mike
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Re: Timing roller 180 out
Post by CudaMan » Wed Aug 21, 2019 2:27 pm
Some camshafts have the hole for the timer roller indexing pin drilled all the way through, remove the timer roller assembly and see if there is another hole 180 degrees opposite the one that the pin is currently installed in. :)
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Wed Aug 21, 2019 2:31 pm
You may have a camshaft with the hole which receives the roller index pin bored clean through. If so, simply remove the pin, and position the roller correctly.
"Get a horse !"
Jim Sims
First Name: Jim
Last Name: Sims
MTFCI Number: 13377
Post by Jim Sims » Wed Aug 21, 2019 2:55 pm
Rotate the engine until the number 1 piston is again to the top and then see where the roller is.
Michael Davis
First Name: Michael
Last Name: Davis
Post by Michael Davis » Wed Aug 21, 2019 4:51 pm
Thanks pulled pin put it in other side. Perfect. Now to get it running
Thanks Mike
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Thu Aug 22, 2019 9:59 am
Cams were made this way for a while around 1915. With the hole drilled all the way thru. No idea why.
Post by Wayne Sheldon » Thu Aug 22, 2019 5:14 pm
Speculation. Somebody probably figured they could save two seconds per camshaft by not indexing the hole depth and going straight through. Then, someone else realized it was costing them five seconds to verify the roller was on the correct side during assembly.
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sat Aug 24, 2019 6:47 am
This happened with the very first model T I ever owned. It was simply a chassis and a tractor seat but everything was there to have a moving vehicle. My brother and I decided we could get it running and we didn’t actually know how to start or drive a T. We hooked up a small lawn mover gas tank to the fire wall to bypass the rusty gas tank and wired a 6 volt flashlight battery to the switch. After turning a few times all we seemed to get is a few coughs.
Then my older brother suggested we check which plug was firing when and we discovered that it was 180 degrees off. So we removed the timer cover and set the rolled on the opposite side of the cam shaft. One crank later and the engine roared to life. We didn’t know how to drive the damned thing and so the rest of the day we experimented with driving and eventually figured it out. We drove it for a few days until we wore out the battery. Took us a few more weeks to realize that all we needed to do was to switch to magneto. At that point we also discovered that the magnets were strong enough to start the engine.
