1922 Center Door (Maybe I should start a dedicated thread)
Will_Vanderburg
First Name: William
Last Name: Vanderburg
MTFCA Number: 28382
Post by Will_Vanderburg » Sat Aug 24, 2019 12:08 pm
Keeping myself busy by removing the tattered upholstery from the rear seat backrest spring assembly.
Taking note of a few things, like how the assembly of the upholstery differs from how modern kits are installed. The spring is covered by white cloth, with padding on top of that, then burlap, then the seat materials.
The backrest is finished off by tacking a piece of upholstery welting across the back and at the bottom of the material just above the two finger holes (across the length)
William L Vanderburg
1922 Center Door Sedan
mtntee20
First Name: Terry & Sharon
Last Name: Miller
MTFCA Number: 32583
Re: 1922 Center Door (Maybe I should start a dedicated thread)
Post by mtntee20 » Sat Aug 24, 2019 10:52 pm
Hi Will,
Could you please post a photo of the "clip" at the top center of the backrest that hooks into the "loop" on the car framework under the oval window? I have seen the "loop" in my reusable items but we did not have a backrest nor seat base when we purchased our center door.
I hope those articles helped you figure your widows out.
Thank You,
Terry
Will_Vanderburg
First Name: William
MTFCA Number: 28382
Post by Will_Vanderburg » Sat Aug 24, 2019 10:56 pm
I'll post it sometime tomorrow. I'm going over to a guy's house to get an engine running.
Will_Vanderburg
First Name: William
MTFCA Number: 28382
Post by Will_Vanderburg » Sun Aug 25, 2019 7:34 am
Here’s the clip that slides into the rear belt rail
mtntee20
Last Name: Miller
MTFCA Number: 32583
Post by mtntee20 » Sun Aug 25, 2019 1:55 pm
Will,
Thank You. That's pretty much exactly what I expected. Just a flat bar bent to fit to hold the seatback in place.
Good Luck,
Terry
