Cleaning old grease in black top
Posted: Sat Aug 24, 2019 7:16 pm
by Mark Osterman
Iโ€™d like to clean some of the old established oil / grease droppings on my paved black top drive way. Has anyone tried enzymes like those used in drains?
Re: Cleaning old grease in black top
Posted: Sat Aug 24, 2019 7:36 pm
by Scott_Conger
I'm thinking out of the box here: how about a long-nap roller and 5 gallons of oil? An even look on the driveway, and spots will never show again :D
Posted: Sat Aug 24, 2019 7:54 pm
by TRDxB2
Blacktop is a mix of asphalt, sand and gravel. Asphalt is a petroleum product. Question is if you used a sealer o top of the blactop that wasn't another petroleum product. problem is , in removing the oil stain you may remove some asphalt. You could try scrubbing with Dawn dish-washing liquid / water mix or oil-dry. There are both latex & petroleum sealers - talked to you local home improvement store to see what you can use.
Posted: Tue Aug 27, 2019 12:37 am
by Greg Griffin
Hi Mark--
I haven't used this product, but I've used their concrete cleaner and it's worth the money.
store.actcleaners.com/asphalt-cleaner
If that doesn't work then just go to actcleaners.com and look around.
Greg
Posted: Tue Aug 27, 2019 12:58 am
by Chris Haynes
Tide and a scrub brush works well.
Posted: Tue Aug 27, 2019 8:31 pm
by Professor Fate
I would try a 3 step process.
1) Put an ample layer of either SPEEDY DRY or CAT LITTER, 1 inch thick, on the spot you wish to clear.
2) With work boots, shoes, or sneakers, vigorously grind in the material into the spot with your foot until granules have become dust. I have a special 8 inch 2x4 block I use under foot instead of using the sole of one's shoes.
3) Sweep away dust and inspect target area. Repeat as necessary. Then sweep away all material, put down some dish soap, and work it into the spot with your shoe. Let sit for a half hour and rinse with a hose.
stain will barely be noticeable.
"Try it...... you'll like it!" ๐Ÿ‘๐Ÿ˜๐Ÿ‘Œ
Posted: Tue Aug 27, 2019 9:42 pm
by Mark Osterman
Sure Iโ€™ve tried kitty litter several times. Doesnโ€™t do much except become impossible to clean once it gets wet. This is old and hard not fresh oil.
