1919-1927 Generator Parts Postions
Posted: Sun Aug 25, 2019 5:01 am
Ok, I'm looking for information as to where and how these bloody parts fit inside the 1919-1927 Generator.
Small Felt Ring I know it goes either between the bearing and the housing or between the bearing and the armature and I think that the retainer plate (shown in the next picture is what holds this fuzzy little beast either against the bearing or away from the armature...but I'm not sure).
Small Bearing Retainer Plate This is another question, which way does it face and which end of the small bearing is it on...the housing side or the armature side?
And for that matter which way does the larger version on the front bearing (called the oil slinger) face and which end of the bearing is it on, the inside towards the armature or the outside towards the gear?
From the pictures I've seen in the Ford parts book, the bearings are not sealed bearings at all like in the vendor catalogs, but ball bearings requiring oil (which is why there is an oiler on the back of the generator housing. I'm assuming that the front bearing got oiled by the timing gear and all that glop slinging around in there.
Any help and or pictures of these parts in their natural mechanical habitat, would be very helpful and very much appreciated, thanks.
