ILLUSIVE RATTLE SOLVED!!
Posted: Wed Aug 28, 2019 10:33 am
Dear friends, My nearly overwhelming feeling of ineptness is only surpassed by my great joy and relief. I can report I have found and corrected the"rattle" that has plagued me for so many months. I am truly in your debt for the countless thoughts and suggestions you folks have offered me on possible causes and remedies. The critical factor I never gave you is I am running a Reeder high compression aluminum head. The rattle I've experienced is excessively loud "knock" from low octane regular gasoline. I can't explain why the noise ended when I shorted out #3 but with a fill up of 91 octane and a little reduction in spark advance the cursed rattle has stopped. My '23 touring has always run very well but it now sounds just like a Model T should with no additional "wrenchin'" needed. Thank you again for all your thoughts, comments and suggestions.
