What have you done with your T in September?
Topic author - Posts: 2345
- Last Name: Hanlon
- MTFCA Number: 50191
Put in a new (old stock) set of Autolite plugs and checked the points gap. Found I had been a little generous with the grease cup on my Thomas distributor shaft...just about to start slinging it around
I wiped it all off and cleaned the points with brake clean after a little sandpaper. Gap was a little wide, set to 0.020", started right up and now waiting to see if it rains for a test drive.
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Re: What have you done with your T in September?
I test fit the TT on the trailer for its ride to Dearborn this week. 1st time on a trailer since the ride home from Daves in Missouri.
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
Prepping the car for its journey to OCF. Take about 2 n 1/2 days to get there around Chicago.
- Last Name: House
- MTFCA Number: 115
Drove the ‘26 roadster to church today...
I don’t know why I turned out this way. My parents were decent people.
- Last Name: Kelly
Finished up the August overhaul on the 23 Speedster and took it for a run. I kind of miss all the knocking it did. Well maybe not. This little speedster runs right along.
- First Name: Ken
- Last Name: Lefeber
- MTFCA Number: 31968
Took my nephew for a ride to Kohler-Andrea State Park for a pie-iron cooking demonstration and to checked out the critters in the Nature Center.
- First Name: Bruce
- Last Name: Carswell
- * REQUIRED* Type and Year of Model Ts owned: 1924 Model TT
Temperature finally cooled down enough here in West Texas to shoot primer on the TT. Good to see my body work doesn’t show through. Most of the lower panels looked like they had been “adjusted” with a ball peen hammer once I got the very thick 70’s bonds stripped off.
- First Name: Neal
- Last Name: Willford
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1915 Runabout
- MTFCA Number: 50256
Painted the body on my 15 runabout project. I've also been color sanding and polishing the fenders and door. It gets pretty crowded when painting the inside of the car!
- Last Name: Kelly
Neal, what paint are you using?
- First Name: Neal
Eastwood Boulevard black single stage urethane. Great stuff. It color sands and polishes out well.
Not nearly as much as some of the above, but have put new float valves in two of my T's and rebuilt the sediment bulb, turn off on one of them. Also took off a de-mountable to pump up the tire on the third one. Tomorrow, I plan to take them all out for a run and see how they do. Getting ready for a 3 day tour in a couple weeks to Big Bear Lake in California. I will only use one of the cars on the tour, but have been very busy this summer and finally got some time to work on my own cars.
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
I was able to start for the first time my 1911 touring after 8 years of restoration. Sound magical. Thank you RV Anderson who's able to adjust my early coils. I can`t wait to drive her.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Clyde
- Last Name: Gibson
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor Sedan, 1926 Roadster
- MTFCA Number: 32266
Getting the T ready for drive to St. Louis on old Rt66. Packed the wheel bearings today and going to check all the bolts for tightness. My son took his T home to St. Louis yesterday to start working on it. We have been waiting for a new bridge to be finished on old 66. I won’t drive on the interstate. Have a great day. Clyde
- MTFCA Number: 52564
We recharged the magnets in the 21 today. There was just enough magnetism left in them to use the KR Wilson gauge to find N-S, then zapped them in 4 places with the KR Wilson Magnet Battery Charger. Back to running on mag. Ok that was the good news, the bad, I forgot to take the rocker arm cover off the running board and by time I got back to where it fell off, it was flat! Oh poo, but it sacrificed it's self to the car gods for all the trouble the car has been giving me this past few weeks! Maybe it will run better now? Fingers crossed thinking good thoughts
1920 Dodge touring
1920 Dodge touring
Mario
I am really pleased for you. I know the last few months have been slow and painful for you as you waited for the last few parts to all come together. It really is a lovely car. Congratulations.
NH Full Flow Float Valves
- First Name: Mario
Thank you Scott. I learnt a lot and made several mistakes which I repaired with the help of knowledgeable people like you. Thank you all MTFCA members. For sure it was painful sometimes... But now hearing the smooth engine is like music on my ears.
All the very best.
Mario
All the very best.
Mario
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- Last Name: Hanlon
Copied for Mike...
MWalker wrote: ↑Thu Sep 05, 2019 5:10 pmI haven't seen a thread for Sept. yet, so I guess it's about time to start one. I got my engine/transmission in the chassis, and the firewall and steering column in place. There's still a gap between the tranny and the shortened drive shaft, waiting for a new KC Warford to become available.
- First Name: Mike
- Last Name: Walker
- MTFCA Number: 314
Thanks, Jeff.
- First Name: Mike
- Last Name: Walker
- MTFCA Number: 314
NealW -- Your Runabout is looking very nice!
- First Name: Neal
Thanks Mike. I'm almost done sanding/polishing the fenders, and I hope to do the same to the body this weekend. After that I plan on starting the upholstery and top installation.NealW -- Your Runabout is looking very nice!
Neal
- Last Name: Dow
- MTFCA Number: 32344
Installed LED headlight bulbs. Wow, what a difference!!!
- First Name: Melvin
- Last Name: King
I do not know if this counts ,but I was showed how to post pics from desk top . I also got my firewall on and bought Firestone tires and EEC tubes.[image][/image]
- Last Name: King
More pics.[image][image][image][/image][/image][/image]
- First Name: Preston
- Last Name: Wells
- * REQUIRED* Type and Year of Model Ts owned: 1923 Runabout, 1926 TT Truck
- Board Member Since: 2008
Spent a day with the paint gun this week. Got the springs assembled and attached the rebuilt and assembled front end and radius rods on the TT chassis. Hurrican Dorian put me a week behind, but that's where the advantage of retirement comes handy. God bless those effected by that storm.
70shovelhead
"There is more to life than what we see"
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1919 IHC Titan 10-20
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
- First Name: Joseph
- Last Name: Andulics
- MTFCA Number: 9766
Replacing a broken rocker arm stand.
Pictures should help!
- First Name: Jim
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup
26 Roadster has been sitting for a year or so. Poured in a quart of gasoline and she fired right up. Maybe that will give me some motivation. Need to get the pickup bed finished and installed.
- Last Name: Wells
Got a firewall and steering column mounted today.
70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
- First Name: Eric
- Last Name: Macleod
- * REQUIRED* Type and Year of Model Ts owned: 13 Touring, 25 Touring, 27 Fordor, 27 Fordor, 26 Touring, '92 Stynoski, '06 Stynoski owner emeritus
- MTFCA Number: 50125
- MTFCI Number: 19464
My sister and I took out my late father's '26 Fordor for the first time in nearly two years. It was a great day!
1913 Touring
1926 Touring
1927 Fordor (2)
1927 Touring
Stynoski 2006, Nash, Franklin, Lincoln, Cadillac and Buick owner emeritus
1926 Touring
1927 Fordor (2)
1927 Touring
- First Name: Clyde
- Last Name: Gibson
Getting our ‘T’ ready for a drive from Springfield, Mo. To St. Louis on old Rt66. I have 2 kids there so will be good trip.
Well, I finally got all 3 to start today and took all 3 to the gas station, one at a time as well as a gas can to get gas. One had been setting for about a year and the gas was so low it wouldn't start. One has a dead battery about 5 years old, but anyway they all got a good run and they have been rotated in the garage. The one closest to the door gets driven most. For the third one, I have to move the other two, so it gets driven the least. I put the one with the dead battery in the third position and before I rotate again, need to get a new battery. Anyway, I think the fuel problems are over.
- First Name: Ken
Joined the Dairyland Tin Lizzies to the threshere at Pinecrest Village last Saturday.
- First Name: Edward
- Last Name: Baudoux
- * REQUIRED* Type and Year of Model Ts owned: 1927 Fordor 1926 Huckster 1930 Fordor 1930 Tudor
- MTFCI Number: 24216
We brought the Fordor to Greenfield Village for the 6th time, and visited with some good people. Spotted several other Improved Fordors, including this one and Eric's.
Grayling Michigan
1927 Fordor
1926 Huckster
Founding member of Northern Michigan Drone Skeet Shooting Club
1927 Fordor
1926 Huckster
- Last Name: Fisher
- * REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
- MTFCA Number: 31822
I've been out of action for a month or more. Finally got back to "repairing" some fenders for a farm vehicle I'm building. The fenders had an are that was very thin with holes. I made some skin graph panels to support the steel. I originally tried to weld them on but I suck at welding. I didn't used to but do now. In the end I wound up cleaning the fender real good and sandwiching Bondo between the new panels and the fender then Riveted them on with some steel rivets I had in stock. Their good and strong now and will work perfect for what I'm building. I will clean up the area a bit and use some Bondo while trying to keep that pitted rust look before painting.
Just give me time to Rust and I'll be good as new. Wabi-Sabi
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
I loaded "Rusty 21" on a U Haul auto transport today to visit The California Highway Patrol inspector. It seems that after out phone conversation about frames he went online and learned a lot about model T's. I explained to him about date codes. He verified Rusty 21's Engine number and signed off the paperwork. Next stop is The department of motor vehicles to finish off my paperwork.
I also ordered a personalized license plate that reads RUSTY 21.https://i412.photobucket.com/albums/pp2 ... smyeky.jpg
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Hank
Put 21" wheels on the rear of the 1921for more tire on the the ground. Still have 30's up front for now. Still chasing down a miss at some speeds. Compression is 90 across the board warm. (The Raloo Rocket with Chevrolet over head). I know it is not spark as it does the same with distributor or coils. Ether it is fuel or valve float or sticky valve? Don't know. Need to change oil back to 10-30, even with low band backed off and clutch adjusted, gets a lot of creep, sometimes major till it's warmed up. Wants to stall the engine when I put the Warford into gear because I have to used the brake pedal to stop the output shaft. (has a cut down 26/27 brake drum with good lug caps) Have a tour this Saturday.
1920 Dodge touring
1920 Dodge touring
- Last Name: Davis
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
I've been working on my 26 coupe for a couple years, I bought it in 1962, and the last time it ran was 1965 till today.
I finally was at the point to put the radiator on it. It cranked over with the started about twice and ran like a top, ran for about 15 min. I idled it down and you could count the beats of the exhaust running on mag. Got some minor stuff to do biggest thing left is the interior and top. Hopefully I'll be driving it around before the weather turns bad this fall/winter.
- First Name: Bob
- Last Name: Coiro
- Board Member Since: 2009
Not that I expect it to be viewed as a significant accomplishment, I replaced a busted starter button today. Lucky for me, it failed in the open position. Doing this kind of ordinary maintenance had become something of a challenge because of my spine injuries, and with the floorboards out, dropping things through the car to the garage floor once meant getting on my knees and crawling under to retrieve the prodigal nuts, washers, bolts, tools, etc.
Well, this gadget, colloquially known as a "pick-up stick," makes reaching though the bottom of the car quite easy. It has a magnetic tip for ferrous escapees and a claw for grabbing non-magnetic items (and, I suppose, radioactive isotopes). They're available through surgical supply stores and online. Here's where one such gizmo can be purchased online:
[/size]
https://www.walmart.com/ip/RMS-26-Long- ... thena=true
[/size]
- Last Name: Chady
- * REQUIRED* Type and Year of Model Ts owned: 1924 Fordor
Went to a car show 25 hilly miles away. Made it with no issue. Had to stop for a photo op with my navigator and chief mechanic.
And in Band White
1920 Dodge touring
1920 Dodge touring
- Last Name: Hanlon
Tim M and Joe A did some picking today and we took my touring for a little spin. Definitely running better after some fuel tinkering.
Both complemented me on my car running well
Felt good after the temperature had climbed up today quickly.
Always a pleasure to bs with a couple of knowledgeable T fellows and make a few bucks too.
- Last Name: Chady
Fixed this! I guess I did have issues on my long trip the other day.
Picked up my wagon full of corn and put it in the barn for my winter heat. I havnt driven the RPU much this summer with the TT on the road. It was a great day, about 72 degrees and sunny. After work I had to pay the farmer so I took about a 15 mile ride!
Well nobody else has posted about their T lately so Im trying to pick up the slack. After the last post, I was hungry and the wife is at work. I headed to town for supper. Made it home before the sun was down!
- Last Name: Chady
Drove a few miles down the road to get some plumbing. I've got about 400 miles on this old car in 2 weeks.
Took the Chevrolet overhead conversion off and went back to stock. That means a 40LB compression drop! (90 down to 50) Been having too many back fires thru the carb so need to reassess the springs I used or look for sticking valve. Did find I should have been running a sacrificial anode even with anti-freeze, the passages were getting goobered up in the aluminum adapter. May need to resurface the head again before it goes back on, I could see were there was blow-by between the head and gasket at the back of #4. When I was looking at the conversion in prep to taking it off, almost wanted to cry because of all the work I have done to put it on. I really didn't need the Warford with the conversion except for overdrive on the flat, but sure am glad I didn't take it off like I was going to. Think I will be needing the in-between gear now.
1920 Dodge touring
1920 Dodge touring
- First Name: Neil
- Last Name: Haywood
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster
- First Name: Gregory
- Last Name: Scholz
- MTFCA Number: 30705
Taylor and I took T to the pizza buffet today.
I do not know why this is upside down. It appears correct on my iPhone.Greg Scholz
4th Generation Caretaker
1914 Ford Touring
Survivor Class
http://personal.gregscholz.com/
Esko MN
KD0UYN ‘73
1914 Ford Touring
Survivor Class
Esko MN
KD0UYN ‘73
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
Nothing to mine, but got about a dozen carbs in the mail, spent several hours on the phone with people walking them through how to do their own carb, bought three big boxes of carbs including some pretty unique ones, bought a new 6 V alternator for my coupe along with some other parts, bought two Ruckstells at an auction -- actually had a friend buy them for me since I was too busy to go to the auction -- made a plan to meet him and pick them up that didn't work out so they are still a couple hundred miles away. Spent a couple hours taking pictures and making a list of about 20 engines and blocks I'm going to sell if I can get an ad running and have time to deal with them, stood and stared at the speedster project I bought three or four years ago, etc. Didn't go on the T tour that ended today even though I wanted to cause my T wasn't ready and I didn't have time. Maybe next month I will get it put inside or go for a drive. Haven't started it since the tour in July. I dunno how it got close to the end of September.
- First Name: Neal
On my 15 runabout restoration project, so far I've completed the painting (https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=6764).
I've also finished rebuilding my coil box, which go with the coils rebuilt my Erik Larson. I've also finished staining and varnishing the wheels. Sorry, but I just couldn't paint those Stutzman wheels black!
- First Name: Bob
- Last Name: Benner
- * REQUIRED* Type and Year of Model Ts owned: TT 1924, touring 22
- MTFCA Number: 52622
- Last Name: Nunn
- MTFCA Number: 50321
My clutch adjusting bolt was upside down and the brake lever had to swing too far forward to clear the bolt's head. I couldn't install my newly finished floor boards. The metal trim plate would not allow enough travel to get into high gear. I flipped the bolt and can now install the floor boards.
I made a guess as to the proper clutch adjustment starting point and I rolled the car a few feet in the shop while watching to see if the engine turned. That's when I confirmed that my ring and pinion gears are shot. I could hear the teeth skipping. I guess I have a new next-project. At least I know I have good gears (and bad bearings) in my spare rear end and torque tube.
- Last Name: Chady
Took a 75 mile round trip in the rain today to the East Troy Railway Museum. Got to ride a 1929 electric trolley. Stopped at the ice cream shop next door for a treat and a photo op. Slight hill in front of the building so I parked in a way that my brakes would hold. Then I went inside to see this on the menu. Had to go back outside to retake the photo. I guess the guy in the TT was afraid of his truck rolling away too!
- Last Name: House
- MTFCA Number: 115
Went into town this morning in the 100 year old Taurus (centerdoor) to get a haircut. Unfortunately the exhaust pack nut came unscrewed and slid down the exhaust when about 1/2 mile from home. Turned around because I was scared the floorboards might catch fire, then the car, then me...and I wouldn’t need the haircut. So I cranked up the ‘14 runabout and had a 40 minute Tour into town and a 45 minute Car Show while there. Came home to a cool Manifold and pipe and reattached pack nut. Then made final inclusions of items to take to Rockville IN mañana...
- First Name: Roger
- Last Name: Harmon
- MTFCA Number: 16412
I put a new top on the '17 last Saturday.
Nice work Roger!
- First Name: Art
- Last Name: Morra
- * REQUIRED* Type and Year of Model Ts owned: 24T Touring
- MTFCI Number: 14286
Got newest T started #32 probly my last
Got all the pieces and steering column about done bit heres a pics as pieces are done
- First Name: Eric
Matk Eyre took the 11 Torpedo to Larder Upholstery in Homer, Michigan for trim work. I think it is looking fabulous.
1913 Touring
1926 Touring
1927 Fordor (2)
1927 Touring
1926 Touring
1927 Fordor (2)
1927 Touring
- First Name: Eric
Meanwhile, i am working on a new top and front bow for my 13 Touring. Here it is in disassembled state. The front bow on this car had just about crumbled to dust. The firewall was in similar condition. I worry a bit about the rest of the wood in this car as a result of these discoveries.
1913 Touring
1926 Touring
1927 Fordor (2)
1927 Touring
1926 Touring
1927 Fordor (2)
1927 Touring
- Last Name: Hanlon
That seat is beautiful Eric, looks mighty comfy
- Last Name: Chady
Had the freeze plug pop again. Dumped all my water onto the carb which promptly killed my engine. Drag racers use water injection, so I thought it'd be faster. Nope, died on the side of the road. I pushed her to the local Kwik Trip, borrowed some tools. Pulled plugs, spun the engine to pump out water. Tapped the freeze plug in, reinstalled plugs, put water in the radiator and continued on my merry way. Everyone was amazed that in 20 minutes I had her going again.
- First Name: Forest
- Last Name: Ledbetter
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT Holmes tow truck
- Board Member Since: 2014
Had it around town and participated in antiques in the streets.
We also have our coats for going into the winter
- MTFCA Number: 16175
- MTFCI Number: 14758
I haven't posted a What Have You Done for quite a while, but yesterday and today I did something. I've been using a bike speedometer for several years. It's great when it works, but I've lost count of the times it's failed because of flying rocks and other road hazards damaging the delicate little wiring or knocking the sensor out of position.
The final straw was the latest failure. I found the sensor mounting bracket broken in two and the sensor completely gone. Obviously a front wheel is too dangerous a location, so I determined that I'd move the works to a back wheel.
The location I decided to use required a threaded tube. I drilled down the center of a ¼-20 bolt and cut off the head. I tossed four before I finally got one right.
I figured that the sensor would be safe from flying rocks if I put it inside the brake drum. Mounting the magnet in the drum was pretty easy.
The threaded tube brings the wires in, and the sensor mounting bracket is held by one of the radius rod bolts.
A two-foot length of fuel hose serves as a wire housing up into the frame, out of harm's way, I hope. The hose is wired in place and the wire is held by the same radius rod bolt that holds the sensor bracket inside the drum.
Running with a wheel jacked up in the shop it works perfectly. The real test will be whether it survives out on the road. Even if this works out OK, I'll make a mounting bracket and install wiring for the Garmin. It won't hurt to have two speedometers. I'll also put in a real 1915 speedometer if I ever remember where I put it.
- Last Name: Bailey
- MTFCA Number: 50335
Took mine to the local car show, spent most of the time entertaining many little ones and doing my best to induct 2 couples into the club. I also put linseed oil on it to keep it from surface rusting every time it rains or gets wet while out and about. Since I have been bringing the T to this show every month, more T's are showing up....
Still crankin old iron
- Last Name: Guitar
- Board Member Since: 2012
Trailering up to the Australian Nationals in Maryborough.
I pulled the starter on the TT that gave up at OCF. A quick cleanup on the armature lathe and brushes and its good to go.
My wife and I drove the 26 RPU to town for supper tonight.
- First Name: Joe
- Last Name: Reid
- MTFCA Number: 52067
- MTFCI Number: 22088
New shoes are going on for the 100 Birthday.
- First Name: Joe
- Last Name: Reid
This is 4,221,578 built 7/28/1920 turning 100 next year and just rebuilt.
- First Name: Ervin
- Last Name: Mims
- * REQUIRED* Type and Year of Model Ts owned: 12 rdstr 13 tor 14 tor 15 pickup 22 drs coupe 21 center door
- MTFCA Number: 29375
Hello gentlemen my name is Wayne Mims I have eight Model Tees 5 of them are driven often I work on or drive a Model T pretty much every day I would love to be able to put pictures on this saying but I don't know how and I'm not very good with computers I have a smartphone and I can send pictures two other people but I can't figure out how to put them on here anyway have a great day and enjoy your cars
Oklahoma chrome, Joe?
I went for a three-mile walk this morning. What does that have to do with Model T's? Next week I'll be going to Hershey in search of parts for my T projects. Last year, after three days of walking I was pretty sore. This time I aim to be ready for it before I go.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
Wayne, try this for posting pictures:
1. Email the pictures to yourself using your smart phone.
2. On your computer, open the email that you sent yourself and save the pictures to your desktop.
3. Get into this forum thread, create a new reply, and drag the photos from your desktop into the reply window just below your text. I think there is a limit of five photos per reply.
4. Click on "preview" to make sure that your photos made it into your post.
5. Click on "submit" - done!
Mark has it correct. Drag the photos into your text or attach them below. Both methods work great. More pictures everyone!
- First Name: Joe
- Last Name: Reid
Oklahoma chrome, Joe? :
You bet, Eastwood cadmium paint.
- First Name: Matthew
- Last Name: Weaver
- * REQUIRED* Type and Year of Model Ts owned: 27 Model TT flatbed and 27 Model TT dump
I got the refurbished gas tank back on the TT along with a newly rebuilt carb w/shutoff valve and installed some new plugs and cleaned up the sparkplug wire contacts. Next on to installing the new fuel line and figuring out how to rebuild the sediment bowl on the gas tank. shutoff valve seems stuck open and the handle is broke with a little nub remaining. Not sure if I need it to close since the shutoff valve elbow is in place on the carb now. - Matt
- First Name: Eric
The Eyre '11 Torpedo is ready for pickup from Andrew Larder. Looks pretty fabulous to me.
1913 Touring
1926 Touring
1927 Fordor (2)
1927 Touring
1926 Touring
1927 Fordor (2)
1927 Touring
- Last Name: Nunn
I was tired of looking at my worn out starting crank. The bushing was shot and the spring was missing too. I was planning to build up the shaft with weld and grind it until I scored a piece of hardened 4140 shaft stock. That stuff is hard on drill bits and bench grinder wheels.
The new bushing is in and the spring will go on after the paint cures.
- Last Name: Stroud
- Board Member Since: 2011
Mark, I don't think you have near enough gap/taper for the weld joint. Also, if that shaft is that hard, the handle may well come off in your hand some day. JMHO Dave
1925 mostly original coupe.
Test pic post
