Started at 1:30 a.m. and met Dean Yoder at his place about 9:00. Dean did what he does best, quickly rebuilt the roller and the yoke that holds it for our K roadster. In a couple of hours, it was better than new, and off we went. Arrived at the Pink Pallace in Dearborn a few minutes ago.
Now, a week at Benson, and OCF. It doesn’t get much better........
The roller was worn down unevenly, and the brass holder grooved on the bottom:
Dean turned down a new roller, and tinned then babbitted the uneven surface. Now it’s as good as new, or better.
This is the third Model K Dean has brought back to life, and fifth K motor he has worked with.
The “K whisperer” and I have arrived........ in Dearborn
- First Name: Kenneth
- Last Name: DeLong
Re: The “K whisperer” and I have arrived........ in Dearborn
Rob,Will the racer also be there? Bud.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Sure is a Beautiful Car and entrusted by one of the BEST! Super Job Dean!
All the Best,
Hank in Tin-A-See
All the Best,
Hank in Tin-A-See
Topic author - Posts: 1431
- First Name: Rob
- Last Name: Heyen
Thanks Hank. Yes, Dean's the best.
Bud, unfortunately the racer motor needs attention and won't be out again until next spring. Will we see you this weekend?
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Are you sure Dean knows what he's doing ?
- Last Name: DeLong
Rob,I think those days are gone but ? Bud.
- First Name: Rob
- Last Name: Heyen
Bud, take care. Off to the library this morning. Who would have ever thought my idea of the perfect day would be time spent at a research library. Certainly not my former teachers...........
