Oil dippers on rod cap question
Posted: Tue Sep 03, 2019 2:14 pm
I have never been able to get the search function to work on this website, so if this question has been asked and answered a million times already, make it a million and one!
The friend's Coupe engine with the piston problems has what appears to be almost new rod bearing Babbitt. Hurray! Something done right on this car - finally! Someone has also drilled the rod caps for oil dippers/scoopers. The hole is already through the cap and the Babbitt, so I'll have to stay with the dippers. But - the hole in the cap is only 1/8" and the one in the top of the rod that goes down through the rod's Babbitt is only 7/64". These both seem rather small to do much good, especially the rod cap's 1/8" hole, the one that does all the scooping. I should think it would need to be larger. It is chamfered, but seems too small to do much good. I also would have drilled the hole at an angle to take advantage of the dipper's angled inlet. The caps on these pistons are drilled vertically. Oh, well. Too late now to change. 'Gotta live with it.
The question: Would it be advisable to open up the cap's 1/8" hole to the next size larger or is it too risky with negligible gain? If the consensus is to enlarge that hole, should I drill through the Babbitt down through the cap to avoid chipping the bearing material?
Marshall
Marshall
