Interesting fix to an old problem
Posted: Tue Sep 03, 2019 8:15 pm
Today I purchased a front axle from a friend because the one that came on the car I am restoring had stripped threads on the passenger side lower fork hole. I sand blasted the area to clean up the kingpin holes and surfaces where are the spindle bushing flanges ride and discovered an interesting fix to an old problem. Namely stripped threads in the lower fork. It appears whoever did the work used a sindle bushing. He did a decent job of it. The threaded hole lines up with the upper hole so the kingpin fits as it should. I wonder if the repair was made before Helicoils were available.
