To save my mind and a trip under....is this Open or Closed ? I’m having a brain-spasm today
On...or...Off ???
George Mills
Topic author - Posts: 647
- Last Name: Mills
On...or...Off ???
I’m a guy who only has use of one leg....so working on de-gunking dirty fuel system has driven me nuts and taken months since I can only get down and under 2 times and can’t use a creeper and then spend 2 days recovering...lol
Re: On...or...Off ???
George
it's "on"
it's "on"
George Mills
- Last Name: Mills
Thanks Scott,
This things driving me nuts...but I’ll prevail...eventually.
Move back! Lol
Move back! Lol
Moxie26
- Last Name: Jablonski
George:
Are you riding out the storm in Florida, or elsewhere ??????? PM me as you wish.
Bob J.
Bob J.
bobt
- Last Name: Thompson
I put a SMALL pinpoint of green paint on the handle and another on the fuel line so when they line up, It's "on" Works for me. Bobt
George Mills
- Last Name: Mills
Bob T great idea! I’ll take that...
Bob J we are over on the Gulf coast so spared this time once the errant spaghetti models decided to join the rest from Sunday on...
If the handle lines up with the gas line, it's on.
Quickm007
- First Name: Mario
- Last Name: Brossard
Its on and when the pinion line up the gas line or if the pinion pointed the carb is off. Hope that help! I have the same pinion wich is original.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
Those who posted are very likely correct, but a positive proof, if the engine will run would be to turn the valve in the direction toward the carburetor and run until it runs out of gas. If that doesn't happen within a few minutes, try the valve in the other direction and you will know for sure. Problem with having the valve at that location, it will work for parking to keep from draining the tank, but you will still need to crawl under to turn it off if you want to remove the carburetor.
NHUSA
- First Name: Fred
- Last Name: Dimock
- * REQUIRED* Type and Year of Model Ts owned: 1919 T with Mifflinburg Suburban body
That used to confuse me also.
Finally I drew a picture on the garage wall so I didn't forget.
It helped me when I was at home but I couldn't take the garage with me on a trip.
NH - Where I used to live - not the carburetor !
Duey_C
- First Name: Duane
- Last Name: Cooley
I'm so darned forgetful and so many valves to remember. 80's Kubota engine coolant drains and even 100 year old water drains on some engines/tractors are opposite of what one might expect but coolant drains are easier to learn. With a piece of wire to test!
My solution.
UGH, yes I know it's a rats nest of incorrect in there.
My solution.
WayneJ
- Last Name: Jorgensen
It is somewhat comforting to know I am not alone. I took a picture of my valve in the open position and store it on my phone in a separate "album" titled: "starting model t", so I can remember.
Wayne Jorgensen, Batavia, IL
1918 Runabout
1918 Runabout
