Fordson Magneto Question
Posted: Wed Sep 04, 2019 2:08 pm
I have a 6V battery backup on an F to aid in easy starting. It will start on mag when warm, but it starts easier on battery. There is a knife switch from a hot shot battery box that allows me to switch from the magneto to battery or open the knife for off. The original setup just had a single wire from the magneto post to the coil box, and the later tractors like mine have a second wire from the magneto post to a ground post on the extreme end of adjustment of the timing lever. This allows the operator to ground the magneto and shut the engine off from the operator's seat. See this post for someone else's photos. http://www.mtfca.com/discus/messages/70 ... 1505813306
One day I forgot to switch the knife switch from battery to magneto. I later grounded the magneto through the timing lever post while the coils were running on battery. The engine sputtered and fluttered around without dying. I un-grounded the magneto and the engine returned to running like normal, on battery. Worried that I had just scrambled the magneto magnets, I switched the knife switch to magneto, and the engine continued to run like normal.
What happened when I grounded the magneto while running the engine on battery? Why did the engine run roughly? The magneto was still disconnected from the coil box input, I was just creating two circuits with a common ground. Did I have a near miss of scrambling the magnets? I think I'll mistake proof this system of mine, but I'd like to understand the risks as is and what happened electrically. Thanks.
