Need HELP Wire Wheel Spindles
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Post by Mustang1964s » Thu Sep 05, 2019 9:27 pm
HELP!
I am the in the process of swapping rear ends. I really hurt my ruckstell.
Long story short. I pick up an original '26-'27 rear end so I can go to the Texas T-party.
Well Now I need some original style rear hubs. See the pictures.
Any idea where I can pick up a set, or does anyone have a picture of what I am really looking for?
Any idea what they might be worth?
Please help I am running out of time.
Steve Hughes
Last Name: Hughes
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Re: Need HELP Wire Wheel Spindles
Post by Steve Hughes » Thu Sep 05, 2019 10:11 pm
You could get a set of floating hubs for wire wheels.
Last Name: Hjortnaes
Post by DHort » Thu Sep 05, 2019 10:19 pm
That is a front hub, not a rear hub. Rear hubs have brake drums on them.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Thu Sep 05, 2019 10:31 pm
That is a floating hub. You need a T wire wheel hub to use it. It also requires modification to the housing.
Andy
Post by Mark Gregush » Fri Sep 06, 2019 2:43 am
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Sep 06, 2019 5:56 am
Steve,
I have plenty of spare hub sets. Let me know if I can help. As others have stated, you will have to cut some off of the tube after removing the Hyatt Bearing. Simple fix and those safety hubs work great.
All the Best,
Hank
Mustang1964s
Post by Mustang1964s » Fri Sep 06, 2019 1:06 pm
Found a set of rear hubs.
They should be here on Monday.
I really thought I was stuck between a rock and a hard spot.
Thank you for all your help.
