Bow Saddle
Topic author - Posts: 97
- Last Name: Aldrich
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1923. 1927
Bow Saddle
The saddle that my top bows rest on when the top is down is loose. I know there is a nut on it inside but for the life of me simply peeling back the panels I cannot reach that nut to tighten it.
Suggestions? Tricks?
John Aldrich
Typical Model T Addict
- MTFCA Number: 4838
- MTFCI Number: 115
Re: Bow Saddle
Isn’t a nut inside, only a female thread boss on the metal upright strut. Use a pipe wrench or vice grip pliers to snug the top prop rod.
Appears to me your prop rod has a bullet nose sleeve over the outer end, might be there to increase the rod diameter for earlier saddle, early have 5/8” hole, later 23-27 have 1/2” holes for the later 1/2” prop rod.
- Last Name: House
- MTFCA Number: 115
Re: Bow Saddle
You have a ‘26-‘27 touring. That forged saddle should have a 1/2” hole for your “prop rod”.
I don’t know why I turned out this way. My parents were decent people.
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: Bow Saddle
Hey John - 2 different parts - "top prop rod" threads into a boss on the body support iron as Dan stated - "top saddle" has it's own square head set screw which tightens onto the top prop rod - one or the other is coming from together !
Re: Bow Saddle
Got it and thanks!
The FORUM has aided me once more!
John Aldrich
- MTFCA Number: 121
- MTFCI Number: 16310
Re: Bow Saddle
Why not put your top up, so you can see what you are doing?
