What is this hood?
Topic author - Posts: 988
- First Name: Jeff
- Last Name: Stevenson
- MTFCA Number: 50006
What is this hood?
Anyone?
It's a LOT different from this hood
. This is like a game of Clue.... I really need a visitor or two to come to Santa Rosa and help me identify half this stuff....
Jeff
Jeff
Assistant WebSite Admin
Voltage Regulators, Starter & Generator Repair
www.modeltregulators.com
www.modeltstarters.com
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
Re: What is this hood?
Jeff, the first(rusty) one appears to be a '26-'27 hood. The second one(primered) one appears to be a repro hood for a '24-'25 high radiator. Dave
1925 mostly original coupe.
David S is right on!
I think David is correct, however, the side panels are on backward. The louvers should be facing out.
- First Name: Donnie
- Last Name: Brown
- MTFCA Number: 49575
I agree with the others. top is 26-27 and the bottom is repro 24-25. I would love to come and play "Clue" with you. but the commute would be a little rough .. Just keep posting the stuff here, we will all help figure it out .....
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
I think Langs has measurements on their hoods in the catalog. Can be confusing if sides are on wrong side.
- MTFCA Number: 28924
Had to look twice but the lovers are indeed on backwards on the 24-25 high hood. The panels are in great shape. In the 24-25 hood pic it looks like the panel in the right corner of the pic is a low hood panel. Maybe!
- First Name: Jeff
This is great. Right down to the backwards side panels! It was a puzzle. There are just dozens of pieces everywhere and Im piecing them all together best I can. I did match the bottom one to my '21, so that wasn't too bad. This guy loved rust colored primer. Better than rust by itself I suppose!
Jeff
- First Name: Jeff
John kuehn wrote: ↑Mon Sep 09, 2019 9:39 pmHad to look twice but the lovers are indeed on backwards on the 24-25 high hood. The panels are in great shape. In the 24-25 hood pic it looks like the panel in the right corner of the pic is a low hood panel. Maybe!
Good eye. That's yet another set entirely. That's the one I matched to my '21.
Jeff
Maybe a repo also but not sure.
Hood dimensions
- First Name: David
- Last Name: Stroud
Fellers, look again at the '24-'25 hood. The panels aren't on backwards, your looking at the shadows. The dimples for the hood hooks bear this out. Dave
- First Name: David
- Last Name: Stroud
Yep, never mind. I was thinking about them being on inside out, backwards didn't register. Yeah, I looked again. Dave
- First Name: Don
- Last Name: Demio
- * REQUIRED* Type and Year of Model Ts owned: 1919 T
- MTFCA Number: 27167
- MTFCI Number: 20405
Jeff,
Just a suggestion to help us help you would be to include a yard stick/tape measure next to an item so we have a scale as a size reference.
Best of luck with your quest,
Dom
Dom
