Hot or Cold
Posted: Tue Sep 10, 2019 9:27 am
by dunoon
I'm trying to install replacement throttle and spark rods. They need some major realignment and are impossible to bend with just my hands. I was going to bend them is a vice and thought maybe I should heat them first. Any suggestions? Thanks
Re: Hot or Cold
Posted: Tue Sep 10, 2019 12:52 pm
The material should be stainless steel if new ones. Just cold bend for simple bend.
Years ago got a set, but they weren't matched pair, so I just bent the spark lever cold, from the throttle rod supplied instead of a spark lever, a bit of a wiggle in the bend before the quadrant, but it works, just if you look close you can see the wiggle... :( One of these days might replace...one of these days :roll:
Re: Hot or Cold
Posted: Tue Sep 10, 2019 2:59 pm
by dunoon
For clearification rods are the ones that run from the steering column to the timer and the one to the carb.
Re: Hot or Cold
Posted: Tue Sep 10, 2019 3:20 pm
by Ruxstel24
Bend them cold, a couple of crescent wrenches and a extension in the hole of the handle works.
There's a Ford tool for that, like a fork.
