Elbow bolts
Posted: Wed Sep 11, 2019 9:39 am
by Oldav8tor
Quick question - If I remove a bolt from the elbow (cooling system) attached to the side of the block will coolant run out of the hole? I may need to install a bracket and want to know if I need to drain the coolant down before doing so.
Re: Elbow bolts
Posted: Wed Sep 11, 2019 9:45 am
by Henry K. Lee
Normally it should not be a problem. Just make sure you do not bottom out in the thread well straining the boss. The threads do not go into the cooling system unless someone before you over did it.
Hope this Helps,
Hank
Re: Elbow bolts
Posted: Wed Sep 11, 2019 10:27 am
by Mark Gregush
Why risk making a mess if the water inlet pulls loose, just drain the radiator.
Re: Elbow bolts
Posted: Wed Sep 11, 2019 11:43 am
by RajoRacer
No worries IF you're just removing 1 bolt.
Re: Elbow bolts
Posted: Wed Sep 11, 2019 12:07 pm
by Mark Gregush
if it is just one bolt, go for it. I was thinking horn bracket.
Re: Elbow bolts
Posted: Wed Sep 11, 2019 7:25 pm
by Oldav8tor
I may drain the radiator down some just in case. It would be just one bolt at a time but then again, why risk it? I'm waiting on a horn I bought from Hank and don't know if I'll use the bracket on it or adapt it to the one already installed.
Thanks for your comments
Re: Elbow bolts
Posted: Wed Sep 11, 2019 8:05 pm
by TRDxB2
You can also park (or jack up the rear) to cause the water inlet to be higher than the water level in the radiator.
Re: Elbow bolts
Posted: Wed Sep 11, 2019 8:25 pm
by perry kete
Unless you pry on the elbow and break the seal between the head, gasket, and elbow you will not have a leak by removing one bolt to attach the horn bracket. Everything is "welded" together by the paper gasket and any sealer used to attach the gasket. If it does weep a little it will stop when you replace the bolt and horn bracket and tighten it down. I have removed that bolt at different times to remove my horn and never had an issue.
Re: Elbow bolts
Posted: Thu Sep 12, 2019 8:18 am
by Mark Osterman
“Water inlet”
Re: Elbow bolts
Posted: Thu Sep 12, 2019 9:49 am
by Rich Bingham
TRDxB2 wrote: ↑Wed Sep 11, 2019 8:05 pm
Please show us a picture of a Model T in that position.
Re: Elbow bolts
Posted: Thu Sep 12, 2019 11:36 am
by TRDxB2
steeper slope needed
Re: Elbow bolts
Posted: Thu Sep 12, 2019 2:43 pm
by Rich Bingham
Much steeper !
great photo !! Thanks for posting it !
Re: Elbow bolts
Posted: Fri Sep 13, 2019 10:25 am
by Original Smith
How about water inlet bolts?
