Tire options for 26 Ton Truck
choirsilva
First Name: Christopher
Last Name: Silva
Post by choirsilva » Sun Sep 22, 2019 7:55 pm
A newbie to T life, have a 26 TT that is now running and desperately in need of new tires, flaps and tubes.
The current tires are marked as follows: Front: 4.40 - 4.50 - 21 4 ply. Rear: 32 x 6.6 14 ply
Thanks,
Christopher
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Re: Tire options for 26 Ton Truck
Post by Burger in Spokane » Sun Sep 22, 2019 8:15 pm
First of all, no pictures, it never happened. Let's see this TT of yours !
I run Lucas 6.00 x 20's on the rear, and had some hand-me-down skinnies on the
front, that look out of proportion to the rest of the truck (seen below). I recently
put some Fisk 4.40/4.50 x 21's on the front that look much better, much of which
is a more "truck-like" tread.
Where in Oregon are you ?
choirsilva
Last Name: Silva
Post by choirsilva » Sun Sep 22, 2019 8:23 pm
Oh, it happened, i’m In Fairview just east of Portland
Burger in Spokane
First Name: Brent
Last Name: Burger
Post by Burger in Spokane » Sun Sep 22, 2019 11:15 pm
Mmmm .... thet thar is a good lookin' truck ! 👍
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Sep 22, 2019 11:17 pm
I recently put some Fisk 4.40/4.50 x 21's on the front...
Fisk?!? Those have to be some seriously old tires. Or is the brand still being used?
Burger in Spokane
First Name: Brent
Last Name: Burger
Post by Burger in Spokane » Mon Sep 23, 2019 12:40 am
I can only assume they are not ancient, as they still look good. Maybe a
current supplier is having this mold and pattern produced ? When my wheels
come back from Stutzman, I will be looking more seriously at what is available
these days. The "skinnies" on my truck are still good, but would look more
appropriate on a car. These Fisks are a little heftier in width and the tread is
more "aggressive", like one might expect for a truck.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Mon Sep 23, 2019 10:32 am
You can't go by looks. My NOS New Zealand Firestones looked new when they came out of the wrappers. They were gorgeous. Country roads ate them up in no time.
Tires made in recent decades should have a date code on them.
mvweaver
First Name: Matthew
Last Name: Weaver
Post by mvweaver » Mon Sep 23, 2019 11:55 am
Nice 26TT. I bought the 6.00-20 Lucas rear tires, tubes, and flaps from Snyders Antique Auto, because it's only about 2hr drive for me to go get them. My truck, while not correct currently has 30x3.5 Firestone tires on the front because I had two good 30x3.5 demountable wheels and rims and didn't have the propper 21" for the front. - Matt
1925TT
First Name: Forest
Last Name: Ledbetter
Post by 1925TT » Mon Sep 23, 2019 11:18 pm
I'm running 700 20's on mine. They have all sorts of options for 700's.
I'm a bit south in Albany Oregon. Nice to hear some other tt's are going to be running around.
1925TT
First Name: Forest
Post by 1925TT » Mon Sep 23, 2019 11:22 pm
Up close
1925TT
First Name: Forest
Post by 1925TT » Mon Sep 23, 2019 11:24 pm
It gives the truck a slight rake to the front. With 21" front wheels.
First Name: John T
Last Name: Tannehill III
Post by JTT3 » Tue Sep 24, 2019 12:02 am
Summit racing has 450-475 21 inch tires for $112 each and free shipping? The fronts tire you have are INSA TIRES, I always had good results with that brand, I don’t know if they make them anymore. I still have a set on the 27 Tudor. If your tube es and flaps are in good shape I’d use them again. I’ve had trouble with the new 21 inch tubes going flat. Your mileage may very. Good luck on your TT.
https://www.summitracing.com/parts/cok-78705
choirsilva
Last Name: Silva
Post by choirsilva » Sat Sep 28, 2019 2:07 pm
Thanks everyone for all of the helpful suggestions, I ordered new front tires from Summit and rears from Langs. I also ordered one new rear tube as I have a very slow leak in the right rear. Drove the truck a couple miles down to the gas station yesterday as a maiden voyage and it did great. I'm totally new to TT ownership as my two old cars are 50s British.
Thanks,
Christopher
Burger in Spokane
First Name: Brent
Last Name: Burger
Post by Burger in Spokane » Sat Sep 28, 2019 9:22 pm
50's British, TT trucks ..... pretty much the same thing !
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Sat Sep 28, 2019 11:28 pm
Well Christopher, TTs are FUN, and you can use them for a lot of other things around the home too! So don't be shy to use it :-)
