Whuzzit??
Topic author - Posts: 3384
- Last Name: Morsher
Whuzzit??
Any ideas ? Very well made casting . We put several of our local peanut brains together and think it may be part of a “in the seat” pull start mechanism. The curved part at the top appears to have been sawed off. The sketch with red is my guess, to mount a pulley . Any help would be great!
- First Name: Henry
- Last Name: Petrino
Re: Whuzzit??
Your pull starter explanation may very well be correct. I was thinking it could be a mounting for an outside magneto, maybe marketed as an easier fix to a failed magneto than pulling the engine. Pure guess.
- First Name: Jeff
- Last Name: Hood
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
- MTFCA Number: 25636
Re: Whuzzit??
It's called a Boston Starter. The cast-in number B S 1 identifies it. Check Jay's post at this link with information on it.
http://www.mtfca.com/discus/messages/50 ... 1439219302
The pictures at the bottom of the post are of my Boston Starter.
Re: Whuzzit??
Thanks very much, Jeff. You nailed it !
