Ruckstell axle
Posted: Sat Sep 28, 2019 12:26 pm
by dacapt1948
I just noticed that my Ruckstell axle width is about 2 inches narrower that my front axle. This is on a 1926 tudor. Question is ,did ruckstell axles come in different widths? My present ruckstell axle has a small backing plate and should have been a large backing plate, which means someone has changed the rear axle.
Thank you
Re: Ruckstell axle
Posted: Sat Sep 28, 2019 12:39 pm
by HPetrino
Alternative theory:
Could it be that your Ruckstell is "standard" width and your front axle is a wide track?
Re: Ruckstell axle
Posted: Sat Sep 28, 2019 1:04 pm
by BobD
I believe standard track is 56.5 inches. Anyone know the exact specification?
Re: Ruckstell axle
Posted: Sat Sep 28, 2019 1:09 pm
by dacapt1948
is track measured from center of tire to other tire center? Also what is a wide track front axle?
Re: Ruckstell axle
Posted: Sat Sep 28, 2019 1:17 pm
by BobD
Yes, center of tires/wheels. May slightly differ in front due to toe in/camber. Wide track axle is 60 inches.
Re: Ruckstell axle
Posted: Sat Sep 28, 2019 3:19 pm
by dacapt1948
Thank you all
Re: Ruckstell axle
Posted: Sat Sep 28, 2019 3:27 pm
by dacapt1948
dacapt1948 wrote: ↑Sat Sep 28, 2019 1:09 pm
What I ment what was a wide track made for and what years?
Re: Ruckstell axle
Posted: Sat Sep 28, 2019 8:48 pm
by KWTownsend
Wide track were made for southern roads where they grew cotton. The cotton hauling wagons were wider, so the road "ruts" were wider. Ford made Wide Track cars to accommodate southern roads.
Here is a photo comparing axles, courtesy of Peter Kable.
- wide track axle.jpg (101.32 KiB) Viewed 4589 times
Peter is from down under, which explains why one axle is upside-down.
