Leaning a little
Posted: Sat Sep 28, 2019 7:27 pm
I noticed that my runabout leans a little towards the drivers side. I assumed it was because I weigh about 230 lbs and am generally the only one in the car on my frequent trips. I tried a topic search and only found one thread. Seems that it might be caused by some shifting of either the front or rear spring. I get the sense that if I loosen the U bolts, lift the body and wrangle it I might be able to straighten things out.
So I realized today when I looked at the front spring that the two threaded bolts on the “front bearing and spring clip” are much longer and required spacers for me to tighten the nuts when I originally put my car together. So now I’m wondering if this clip is for a truck ... or if I have too few leaves. How many leaves were usually used on a ‘23 runabout?
