Question re gas filter
RGould1910
Last Name: Gould
Post by RGould1910 » Mon Sep 30, 2019 1:52 pm
What are folks using for an inline gas filter on a 26-27 set up. Concerned about the close distance to the exhaust manifold if I mount a plastic filter under the shut off. Any photos would really help.
Another question comes to mind. I have gas seepage at the shut off coming from the front. I wound a piece of teflon string in place of the felt but I question whether it will deteriorate in contact with gas. Any thoughts?
George N Lake Ozark
First Name: George P
Last Name: Clipner
MTFCI Number: 18665
Re: Question re gas filter
Post by George N Lake Ozark » Mon Sep 30, 2019 3:26 pm
Under the big brass nut that goes into the casting is a leather washer. Get out a big wrench and snug it up but not so tight that the valve lever won’t turn or bind. New leather washers are available (got mine from Lang’s) if needed. I have some pics but can’t upload from my phone. I’ll try later when at home.
RGould1910
Last Name: Gould
Post by RGould1910 » Mon Sep 30, 2019 3:53 pm
Thank you. Right now the piece has a felt instead of a leather washer. I'll purchase one from Langs. Thanks for the tip!
First Name: Jeff
Last Name: Humble
* REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
MTFCA Number: 28034
Board Member Since: 2006
Post by Humblej » Mon Sep 30, 2019 4:17 pm
Richard, no additional gas filter is needed. The filter is a screen in the sediment bowl. You can open up the bottom of the sediment bowl to inspect and clean the screen. Uses a lead washer to seal the bottom fitting, reusable if you don't damage it, available from the usual vendors if you do.
Tom Hicks
First Name: Thomas
Last Name: Hicks
* REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
MTFCA Number: 32518
Post by Tom Hicks » Mon Sep 30, 2019 4:54 pm
Every gravity fed carburetor needs a fuel filter.
There are some who have had their car not run well, so they removed a fuel filter and then it ran fine. So they decided the filter was the problem. The DIRTY filter was the problem. When one removes a dirty filter it should be replaced with a new filter.
It does not take much trash to mess up a NH, hitting a good bump will dislodge trash from an old fuel system. The fuel filter needs to be close to the carburetor to insure that you do not end up rebuilding it.
Tom Hicks
First Name: Thomas
Last Name: Hicks
MTFCA Number: 32518
Post by Tom Hicks » Mon Sep 30, 2019 6:30 pm
Tom Hicks
First Name: Thomas
Last Name: Hicks
MTFCA Number: 32518
Post by Tom Hicks » Mon Sep 30, 2019 6:36 pm
I think it is the same one Stan Howe recommends:
"No gravity feed carburetor should be installed on any engine with out a good quality filter just prior to the carburetor and a shutoff near it. "
https://www.mtfca.com/phpBB3/viewtopic. ... 686#p35569
RGould1910
Last Name: Gould
Post by RGould1910 » Mon Sep 30, 2019 8:26 pm
Anyone ever try the glass bowl filter sold for model A's by Snyder's?
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
MTFCA Number: 28967
Board Member Since: 2010
Post by Charlie B in N.J. » Mon Sep 30, 2019 9:17 pm
You need a filter designed for a gravity fed system. Like riding lawn mowers. A mower shop will have the type you need. Used them for years no problem.
Last Name: Hjortnaes
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Tue Oct 01, 2019 11:53 am
I prefer this screen from Snyders. Fits perfectly in sediment bulb. Just type screen in Snyders web site.
https://www.snydersantiqueauto.com/Prod ... hByKeyword
Picture won't load.???
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Tue Oct 01, 2019 12:59 pm
One that takes up very little space, Briggs and Stratton for a 18/20 hp.
