reducing 12v to 6v
Don ellis
First Name: Don
Last Name: Ellis
reducing 12v to 6v
Post by Don ellis » Wed Oct 02, 2019 6:49 am
I have a model a aooga horn I want to use. What's the best way to knock it 12 down to 6? besides putting a 6v battery in.
thanks
First Name: Henry
Last Name: Lee
Re: reducing 12v to 6v
Post by Henry K. Lee » Wed Oct 02, 2019 7:03 am
A Dodge style ballast resister from the 1960’s works good.
Hope this Helps,
Hank
Cambin
First Name: Cameron
Last Name: Smythe
Post by Cambin » Wed Oct 02, 2019 7:14 am
Hi Don I have done this with a piece of 0.8 mm stainless welding wire and cut about a foot and a half off and wound it around a half inch drill shank ant tried it then kept cutting it back until I got the right resistance
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Oct 02, 2019 7:37 am
Works well Cambin!
Hank
Cambin
First Name: Cameron
Last Name: Smythe
Post by Cambin » Wed Oct 02, 2019 8:35 am
Yes hank works well
John.Zibell
Last Name: Zibell
MTFCA Number: 30265
MTFCI Number: 24046
Post by John.Zibell » Wed Oct 02, 2019 10:54 am
or just make a simple voltage divider. Two resisters of the same value, and tap from between them. Just be sure they can carry the current.
1926 Tudor
Don ellis
First Name: Don
Last Name: Ellis
Post by Don ellis » Wed Oct 02, 2019 1:27 pm
Thanks guys, I’ll be trying some of these.
George N Lake Ozark
First Name: George P
Last Name: Clipner
MTFCI Number: 18665
Post by George N Lake Ozark » Wed Oct 02, 2019 6:13 pm
I found this online at autozone
929FC1E2-5A5F-4ABD-A2F1-8695CCEEFAB1.jpeg[/attachment Also found this online at a rat rod supply, haven’t tried tried yet . [attachment=1]929FC1E2-5A5F-4ABD-A2F1-8695CCEEFAB1.jpeg
art32mor
First Name: Art
Last Name: Morra
MTFCI Number: 14286
Post by art32mor » Wed Oct 02, 2019 8:05 pm
Double resisyer will do it
A parts guys sell a unit ready to go
VW guy have one as well
Matt in California
First Name: Matt
Last Name: G
MTFCA Number: 30697
Post by Matt in California » Wed Oct 02, 2019 9:08 pm
I have used wire like Hank above. I have also used a resistor (see picture). Depending on the current draw resistance values may need to be changed. A voltage divider with equal value resistors would be problematic for something drawing a lot of current. If the Horn drives around 1 Amp at 6 volts, a one ohm series resistor will drop 6 volts. I had a .6 ohm resistor handy it dropped about 4 V leaving 8 V on the horn.
Matt
