Cracked Clutch Plates
Posted: Thu Oct 03, 2019 7:51 pm
by got10carz
I've taken apart alot of transmissions, but I dont remember ever finding this many cracked discs. Can't imagine the heat it took to do this.
Re: Cracked Clutch Plates
Posted: Thu Oct 03, 2019 8:28 pm
by Henry K. Lee
WOW! Never seen that! Maybe my Dad back in his youth drag racing? LOL
Hank
Posted: Thu Oct 03, 2019 8:51 pm
by Ruxstel24
Improper adjustment and/or a weak spring, would be my hypothesis.
Posted: Fri Oct 04, 2019 11:33 am
by RajoRacer
How torn up is the clutch drum ????
Posted: Fri Oct 04, 2019 12:11 pm
by Scott_Conger
And THAT, Steve, is the $64,000 question, isn't it?
Posted: Fri Oct 04, 2019 12:59 pm
by Moxie26
Worn thin, or just cracked ? Running low on oil ?
Posted: Fri Oct 04, 2019 2:20 pm
by Steve Jelf
I've seen lots of them, but not like that.
Posted: Fri Oct 04, 2019 3:43 pm
by got10carz
The drum has groves worn, but I've seen worse. Improper adjustment, bad driving skills, and a oil pan with a plug in the top hole all could be factors.
Posted: Sat Oct 05, 2019 8:23 am
by Alan Long
My initial thought on those plates is they are “flexing” in operation going from flat to dished. The cracking appears to be
adjacent to the cut out on the outer plates. As suggested by others a possibility is catching on the drum and not sliding
I’m aware of some rebuilders who intentionally bend one or two plates into a dished form to give a quicker cleaner
disengage into neutral. Alan
