Are the rear spring the same between Ts?
Will a small drum mount up to a set of springs that came off of '26/'27?
I am thinking that there is not any difference, but I have been wrong before.
rear springs same
Topic author - Posts: 254
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926
- MTFCA Number: 29784
- MTFCI Number: 22970
- First Name: Bill
- Last Name: Robinson
- * REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
- MTFCA Number: 22487
- MTFCI Number: 17887
Re: rear springs same
Go to this mans website and you will see that there are a few different spring sets for a model T.
http://t-springs.com/products.html
There is a difference in the arch of the springs, 09-25 (small drum) vs 26-27 (large drum), and the spread length 46-3/8" vs 43-1/4" respectively. Also the rear cross member on the frame needs to match. Haven't tried it so can't answer the question - will it fit
The two rear ends that I have are '26/'27 and they are currently out of commission.
I am trying to gather part to rebuild.
A club member has let me borrow a small drum Ruckstell.
Besides not having a hand brake. What other issues am I looking at?
- MTFCA Number: 52564
The 1928 parts book listed the rear spring as the same 1909 to 1927;
http://www.cimorelli.com/mtdl/post-1927/1928plaug.pdf
The arc of the rear cross member was changed for 1926-27, it was taller to drop the body down. I mounted a big drum rear under my 21 without changing the spring with no issues. The only difference might be the number of leafs between body styles.
1920 Dodge touring
1920 Dodge touring
