Help with LED/headlamps...
Posted: Sat Oct 05, 2019 12:56 pm
Hey guys, having a weird issue with my LED headlights (one actually). The passenger's side keeps burning out. I think that it may be a wiring issue but would like to hear from some of the more experienced electrical guys on this one.
Info.
Car has a mag and battery but I run the headlamps off of a small 12v battery that is wired into the system like a normal battery would be, mag is not in that circuit. The correct loom comes up the passenger side of the engine compartment toward the passengers side headlamp as it should. In the loom one wire (hot) runs to one of the terminals on the back of both headlamps. Each headlamp has wires running from the remaining terminals to the frame for grounding.
The driver's side lamp will run for hours with no issue. The passengers side will work for a short while, eventually flashing on and off before it goes out completely. I did notice an odor of electrical burning in and around the headlamp area. I have checked the socket and there is power to one of the terminals and the socket housing seems to be grounded and working.
What am I missing here?
thanks for you help and suggestions.
Info.
