OT Old Photo - my mom's mom driving in a what??
AdminJeff
Last Name: Stevenson
MTFCA Number: 50006
Post by AdminJeff » Fri Jan 25, 2019 2:25 pm
My mom just happened to send me some old pics today in the mail. I won't share my baby pics...
But, here's a picture of her mom in some car in 1936. At least that's what it says on the back of the photo.
Assistant to the Grand Poobah MTFCA Site Admin
1921 Touring
Jim Sims
First Name: Jim
Last Name: Sims
MTFCI Number: 13377
Re: OT Old Photo - my mom's mom driving in a what??
Post by Jim Sims » Fri Jan 25, 2019 2:39 pm
29 Model A Ford. Might be 28. From the smooth cowl I would guess a delux model of the 4 door.
MTFCA Number: 1219
Post by Rich Eagle » Fri Jan 25, 2019 4:10 pm
Briggs body? It might be brand new as there is no license plate.
Steve Hughes
Last Name: Hughes
MTFCA Number: 216
MTFCI Number: 23070
Post by Steve Hughes » Fri Jan 25, 2019 4:12 pm
Wouldn’t be brand new if the picture was taken in 1936.
MTFCA Number: 1219
Post by Rich Eagle » Fri Jan 25, 2019 4:13 pm
Yep, you're right. Still looks new.
Steve Hughes
Last Name: Hughes
MTFCA Number: 216
MTFCI Number: 23070
Post by Steve Hughes » Fri Jan 25, 2019 4:21 pm
Yes, it does look awfully good for a 7 or 8 year old car.
Marv K
First Name: Marv
Last Name: Konrad
Board Member Since: 2010
Post by Marv K » Fri Jan 25, 2019 4:47 pm
Not to be contrary or anything, but the cowl indicates a '30 or '31 to me. The '28-'29 Model A's had a narrower cowl at the firewall, and a front-facing A-Pillar indentation at the back of the cowl which went all the way down to the hood shelf area, much like the '26-'27 Model T's. The picture shows the hood-hinge body line continuing into the rest of the body as well, not stopping for an indent at the back of the cowl below the windshield. This is from the FWIW Dept.
Good keepsake photo!!
"Let's Figgur it owt!" Just fix it (right), and make it work.....
Aah-OO-Gah! (and), "Happy T-ing!"
KeithG
First Name: Keith
Last Name: Gumbinger
MTFCA Number: 4661
MTFCI Number: 6866
Post by KeithG » Fri Jan 25, 2019 5:10 pm
Marv, take another look. The radiator shell says '28 or '29 to me. Going by the crank hole in the lower part of the shell, it looks like a '28.
Just my opinion, your mileage may vary.....
Keith
'14 Touring, '26 Roadster Pickup, '27 Fordor, '25 TT C Cab with Express Bed.
MTFCA Number: 1219
Post by Rich Eagle » Fri Jan 25, 2019 5:25 pm
The bead on the hood and cowl is very deceiving on those '28-'29 Fordors. It does make them look like a '30-31'. I have been fooled a few times.
Marv K
First Name: Marv
Last Name: Konrad
Post by Marv K » Fri Jan 25, 2019 5:39 pm
-Keith & Rich-
Perhaps I've not paid close-enough attention to those '28-9 fordors to ID that part?
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Fri Jan 25, 2019 6:11 pm
Looks like a right hand pinkie to me or maybe an F3 twister.
Vern (Vieux Carre)
wayne sheldon
Post by wayne sheldon » Fri Jan 25, 2019 6:45 pm
Headlamp lenses suggest '28. A long-time best friend many years ago had a '29 Murray Town Sedan (model A Ford). '28 and '29 Ford had a larger variety of sedan models. Most (not quite all) of them had the smoother cowl lines, lack of A pillar offset, and bead on the hood making them look more like the '30/'31 models. Many of the "deluxe" models came standard with cowl lamps, including Steve's Town Sedan. Some "deluxe" models had cowl lamps as options. Most body styles were not available from the factory with cowl lamps in any way in '28 and '29(as with many "options", dealers could sometimes put them on unofficially). In addition to the Town Sedan, sedans were available in various "blind back", "leather back", and standard models (many without cowl lamps). Most Fordor sedan bodies were built by either Murray or Briggs, as were the cabriolets (which as I recall were also available with the optional cowl lamps?).
HaroldRJr
First Name: Harold
Last Name: Schwendeman
Post by HaroldRJr » Fri Jan 25, 2019 7:00 pm
Marv K. - Reich Eagle "nailed it"! It's a 1929 Briggs Town Sedan (155-B)
The smooth & flush cowl sides do indeed make people think that body style must be a '30 - '31, however, the Briggs Town Sedan body was built starting with the '29 model (like this one pictured above) for the rest of the Model A period. As was mentioned above, the radiator shell size & shape is indeed typical of the '28 - '29 Model A, but it is for sure, a '29 Briggs Town Sedan. Murray also built that same body with one slight difference,....the slightly curved top of the side window openings, while the Briggs (as pictured above) had the top of the side window openings perfectly straight. Yes, the '29 Briggs Town Sedan is indeed "unique" design of its' own (and fools a lot of people) as it has the radiator, hood & cowl, front fender design of the '28 - '29 Model A, but also has the flush & smooth and more streamlined side panel design & style of the '30 - '31.
HaroldRJr
First Name: Harold
Post by HaroldRJr » Fri Jan 25, 2019 7:04 pm
Sorry Wayne,...."simultaneous typing" and you explained much more thoroughly,.....(:^).....harold
wayne sheldon
Post by wayne sheldon » Fri Jan 25, 2019 7:07 pm
No worries Harold! I like what you wrote about them.
HaroldRJr
First Name: Harold
Post by HaroldRJr » Fri Jan 25, 2019 7:14 pm
Wayne,....I kinda' sounded like a "know it all" kinda' guy I guess, however, I just happen to own a 1929 Briggs Town Sedan (155-B) "exactly" like that one! (:^)
(.....not often,....but once in awhile,....a subject come up that I actually know something about! (:^)
Post by Mark Gregush » Fri Jan 25, 2019 7:18 pm
I would go with standard late 28 to early 29 leather or blind back Briggs 4 door (2 window) with the old style fluted lens. I don't see a cowl band so don't think it would be a town sedan. If it was an early 28 it would have had the cowl vent which was dropped in late 28. The standard model 4 doors did not come with cowl lights or cowl band. The Town sedan was introduced some time in the calendar year of 1929 (Junish) and for 29 at least was a deluxe model with plated cowl band and lights. I wonder if the date was wrong on the photo, that car looks too new to have been driven any by 1936.
1921 Huckster
Jeff
MTFCA Number: 50006
Post by Jeff » Fri Jan 25, 2019 8:54 pm
Holy cow you guys.... I’m going to have to show this thread to my mom. Her mom never got this much attention. Ever!
Jeff
1921 Touring
"The trick to creativity is knowing how to hide your sources..." Albert Einstein
Post by Mark Gregush » Fri Jan 25, 2019 9:33 pm
To add to this, blind/leather backs are not town sedans. All town sedans had quarter windows which the the blind/leather backs do not.
1921 Huckster
26troadster
Last Name: Lloid
Board Member Since: 2014
Post by 26troadster » Sat Jan 26, 2019 10:44 am
Very cool pic..
david_dewey
First Name: David
Last Name: Dewey
MTFCI Number: 19936
Post by david_dewey » Sat Jan 26, 2019 2:59 pm
Definitely a Briggs Blindback, '28 or '29. Interestingly the '29 was a "plain Jane" model with plain seats (no piping) and less were made than of the infamous A-400 convertible sedan--but guess which one is worth more nowadays? I rebuilt one from a bare, wood-less body shell (with no dents in it!) about 30 years ago. I would question the 1936 date though--the car is VERY shiny, and their is no front plate, but the front plate clamps are on the headlight bar, if it was from a state with no front plates, I would think those clamps would have disappeared by 1936.
Fitting wood rt side forum.jpg (27.5 KiB) Viewed 2496 times
Front seat interior forum.jpg (21.47 KiB) Viewed 2496 times
Out of gas morning forum.jpg (30.37 KiB) Viewed 2496 times
T'ake care,
David Dewey
katmankingkat
First Name: Darvin
Last Name: Jahnke
Post by katmankingkat » Sat Jan 26, 2019 5:55 pm
Screw on radiator and gas caps and small hubcaps indicate 28-29.
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Post by John E. Guitar » Sat Jan 26, 2019 6:20 pm
Here is my Leatherback. It has a November 1928 build date stamped on the firewall.
HaroldRJr
First Name: Harold
Post by HaroldRJr » Sat Jan 26, 2019 10:03 pm
Yup! "Blindback" for sure! Wish I'd had just a little bit better side view on that first almost direct head-on photo and I would not then have made a fool of myself! Ya' gotta' admit tho' that the unusual '28 -'29 radiator that blends into the normal '30 - '31 4-door body lines is the same on the town sedan as well as th "blindback"!
David D.....that color photo you posted sure looked familiar to me! My '29 155-B Briggs Town Sedan is painted exactly the same,....medium gray with the normal black fenders & running board splash shields and all black above the belt line. I didn't paint mine, but I kinda' like it,....almost a bit on the "elegant" side for a Model A!
david_dewey
First Name: David
Last Name: Dewey
MTFCI Number: 19936
Post by david_dewey » Sun Jan 27, 2019 12:38 am
Harold,
Last I knew, that A was in Louisville, KY. I haven't seen it for some 30 years!
If you find a '29 Fordor with the standard "stepped cowl, you've found a factory Taxi Body, almost all metal, and last I knew, only about 3 survived. Yes, radiator shell, etc. is standard. The hood, and cowl are Fordor and Cabriolet only, and the gas tank is the standard '29 tank, hidden under the cowl. the hood is also unique. although I THINK the regular hood would fit the hole (but of course, not look right). BTW, you CAN find '29 type gas tanks with the twist-on/off gas cap; the design was held over on the Commercial truck line for a short time.
T'ake care,
David Dewey
david_dewey
First Name: David
Last Name: Dewey
MTFCI Number: 19936
Post by david_dewey » Sun Jan 27, 2019 12:53 am
Lft Rear painted forum.jpg (30.45 KiB) Viewed 2311 times
PS the car in my photos is dark blue above the belt molding, not black! Here's a pic before I put the body on the chassis. I wonder if I could still do a paint job like that now? That's actually the room I painted it in! No fancy paint booth, just a huge fan in a window frame to ventilate the area. I once painted another model A in a guys carport behind his house--at the car shows no one would believe it--but we'd water down the ground and paint early in the morning before the bugs came out.
Here's another paint job in that same room;
Me painting upper body forum.jpg (26.31 KiB) Viewed 2311 times
and the results
Rt side painted Forum.jpg (29.4 KiB) Viewed 2311 times
I even woodgrained the interior trim pieces (authentic finish--I think the lower one is the original graining clear coated to bring it out)
Interior trim woodgraining forum.jpg (21.02 KiB) Viewed 2311 times
These were done a long time ago, not certain I could do the same today. AAAUGH!!
T'ake care,
David Dewey
