Rebuilding starter
Posted: Thu Oct 10, 2019 8:58 pm
by Autie
My question is, during the dis-assembly, a triangle shape, thin piece of what I think is some type of insulator, fell out of the starter housing. I looked in the Model T service book and unless I am missing it, the book does not mention any such type of triangular insulator. Anybody know what I am referring to and if so, where is it placed? Thank you.
Re: Rebuilding starter
Posted: Thu Oct 10, 2019 9:17 pm
by Henry K. Lee
Keith could have been added years later as an extra precaution of a brush conductor getting too close. Just make sure all exposed conductors have good clearances.
All the Best,
Hank
Posted: Thu Oct 10, 2019 10:43 pm
by Scott_Conger
That is a piece of material called Fish Paper
I more often see them in generators than starters. Typically a point of the triangle is wedged down between coils and housing, directly insulating the post from anything inside.
Posted: Thu Oct 10, 2019 11:05 pm
by Autie
Thank you, guys!
Posted: Fri Oct 11, 2019 5:55 am
by AndreFordT
Hey Keith,
I always replace that triangle insulation with a band of 0.5 mm gasket paper to insulate the windings from the housing.
Goodluck
Andre
Belgium
Posted: Fri Oct 11, 2019 9:49 pm
by TonyB
That triangle piece of insulation has been on every apparently original I have ever seen. So I believe it to be part of the original design. I bought a couple of sheets of 0.015” thick insulation on the web a number of years ago and cut it to shape on the starters I re-build.
