Ideas to remove starter front bushing
Posted: Fri Oct 11, 2019 7:55 pm
Back again! Need suggestion on how to remove the front shaft bushing for the starter. The one pictured in the service book looks like a oversized threaded shaft is screwed into the bushing, then the threaded shaft goes through a plate with a nut on the opposite side to turn, pulling the threaded shaft up along w/the bushing while being held in a vice. Easy enough to make IF this is how it is done.
