Re: Hand Crank Mod
Posted: Mon Oct 14, 2019 7:38 am
by doodlebugt
Hi Terry,
It was "Fast Frank" with the proud crank.
I've often thought about it.
Bruce (still drooping)
Re: Hand Crank Mod
Posted: Mon Oct 14, 2019 10:22 am
Frank in crank-up mode.
Seamus has this upright-crank accessory on his 1914.
Re: Hand Crank Mod
Posted: Mon Oct 14, 2019 1:04 pm
by Thorlick
Steve,
Does Seamus have the driving light on the front axle in case he runs out of carbide?
We have a stretch of state highway between Grass Valley and Auburn which is posted "Daylight Safety Section". Theoretically you must run headlights or risk being cited unless you are female with suggestive clothing. When I had "Toady" (my 1913 Mountain Wagon model T) I used to flaunt this law whenever driving that road because I didn't want to have to clean up the carbide mess for just 28 miles of driving.
I also am "very concerned" about a recent law which mandates you illuminate headlights whenever you "turn your wipers on". Since I use my intermittent mode on Rusty when it is raining (reach up and wipe the wiper across the windshield when needed) I don't turn the lights on each time I wipe the wiper. If I turn the lights on in the daytime I would soon have a dead battery (as a sexigenarian... cool sounding attribute I can use for four more years... it is mandated that I forget to turn the lights off). I feel exempt from this law since I don't ever "turn my wipers on" when I use them (possibly they require a younger more attractive driver to be "turned on").
Ok, back to treating the model T hand crank affected with E.D.
TH
Re: Hand Crank Mod
Posted: Mon Oct 14, 2019 1:15 pm
by Thorlick
Steve, Seamus accessory is a bit hard to see. it is interesting indeed!
- Seamus accesory crank holder.
- crankacc.jpg (49.8 KiB) Viewed 6348 times
TH
Re: Hand Crank Mod
Posted: Mon Oct 14, 2019 4:20 pm
by mcenhillk
I just happened to stumble across this accessory on Lang's this morning.
https://www.modeltford.com/item/3664CH.aspx
Kevin
Re: Hand Crank Mod
Posted: Mon Oct 14, 2019 4:32 pm
Here's a later model stamped steel "OAKES" Krank-Loc on our '14 - I believe the early ones were cast.
Re: Hand Crank Mod
Posted: Tue Oct 15, 2019 7:10 am
by Loftfield
Thanks to Mr. Horlick for explaining the finer points of hand crank positioning. I now know why so many Model T's have that kinky leather jock strap, and the bells (balls?) suspended from the front axle on those cars that are more anatomically complete and correct.
Re: Hand Crank Mod
Posted: Tue Oct 15, 2019 6:49 pm
by Thorlick
Thomas, thanks. I used to hang an old model T magneto magnet below my differential with a bit of bailing wire. It was amazing how many folks accepted my explanation that it was to catch parts which had fallen off!
I took it off when I discovered that it slowed Rusty down whenever we crossed railroad tracks.
TH
Re: Hand Crank Mod
Posted: Tue Oct 15, 2019 8:59 pm
by TonyB
I have one on my 1909, I had never seen one previously so I thought it was special. Now I see they are being reproduced, in brass no less, mine is cast iron.
All my other Ts have a cup and leather strap
