Wood block between 21 body and frame
Topic author - Posts: 626
- Last Name: Seress
- MTFCA Number: 27707
My 21 touring hood slants down towards the rear of the car which indicates the body has to be raised a half of an inch or so for the hood to be straight. The radiator is bolted to the body with only the leather in between so I cannot lower it any. What am I missing? Frank
Re: Wood block between 21 body and frame
Like all T's, your car has a bowed frame. The only true fix is to re-arch the frame
Read this: http://www.mtfca.com/discus/messages/80 ... 1240978095
as well as the rabbit holes it takes you down.
On the bright side, friends have had success at friendly frame shops, with body attached.
NH Full Flow Float Valves
- First Name: Henry
- Last Name: Petrino
Just a thought -
When I took my '18 TT apart I discovered that the radiator (which should have been a low radiator) had been replaced with a high one. Nothing lined up. Of course I replaced it with the correct radiator, but at the time my learning curve was steep.
