Anyone want to venture a guess on what this axle is for?
Topic author - Posts: 234
- First Name: Jeff
- Last Name: Perkins
- * REQUIRED* Type and Year of Model Ts owned: 1913 Runabout 1926 Touring
- MTFCA Number: 10642
- MTFCI Number: 17799
See picture, top axle is Model T, bottom looks exactly like a T but shorter. It has not been cut or welded. Is it for a clown car? How about a FWD conversion? Opinions please!
1913 Model T Runabout,
1926 Model T Touring,
1948 Chrysler New Yorker,
1991 Mazda Miata
1991 Mazda Miata
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: Anyone want to venture a guess on what this axle is for?
Most likely shortened on the gear end - pretty simple machining process to shorten & recut the key & keeper slots.
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
I believe some snow machines used narrower axles.
- First Name: Michael
- Last Name: Peternell
- * REQUIRED* Type and Year of Model Ts owned: TT gas truck, T tractor conversions, '15 touring, '17 speedster, '26 16 valve speedster
I'm going to guess for a tractor conversion. Shaw offered different configurations/ Wheel spacings.
- First Name: Henry
- Last Name: Petrino
I've never had one apart, but does a Ruckstell use a shorter axle on one side?
- First Name: Erik
- Last Name: Johnson
- First Name: Jeff
That’s what Tim Morsher told me!
1991 Mazda Miata
1991 Mazda Miata
The Ruckstell uses standard Ford axles on both sides. I would suspect that axle might have been cut down for a speedster or maybe for a small trailer to be pulled by a T.
- First Name: Rich
- Last Name: Bingham
Model T rear axles were often modified for application on farm implements. Around here, many one-row spud diggers used them. (Blackfoot, Idaho - world potato capitol - )
"Get a horse !"
- First Name: Joseph
- Last Name: Andulics
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor, 1926 Truck, 1927 Roadster GOW, RAJO Sprint car
- MTFCA Number: 9766
Offset rear axle for sprint car
