Stipe cam
Topic author - Posts: 96
- First Name: Art
- Last Name: Morra
- * REQUIRED* Type and Year of Model Ts owned: 24T Touring
- MTFCI Number: 14286
Stipe cam
Reading online but never heard stipe 280 cam cant use adjustable lifters?
And then looked in langs says same thing??
I also found I need shave .018 off my new front cam bearing is this common issue
With stip cam?
With stip cam?
- First Name: George P
- Last Name: Clipner
- MTFCI Number: 18665
Re: Stipe cam
I don’t know about shaving the bearing, but but I’m running the.280 for several years and have adjustable lifters .
- MTFCA Number: 52564
Re: Stipe cam
This might give you more info;
http://www.mtfca.com/discus/messages/33 ... 1376057894
Reading it, not all blocks are the same in that area, some have more room. Depending on how the foot is made, you could run into the same issue with repo stock lifters I would think.
1920 Dodge touring
1920 Dodge touring
- Last Name: van Ekeren
Re: Stipe cam
I've never heard of any issues in using adjustables on the 280, as George states I've ran the same for several years. And as for the bearing, yes new ones sometimes need turning in the lathe for a final fit.
Re: Stipe cam
Could also mean, you do not need a "SPECIAL" lifter. I would consider an adjustable lifter to be equal to non adjustable as a direct replacement.
1920 Dodge touring
1920 Dodge touring
Re: Stipe cam
Haven't seen the lifters that had a higher stem base for several years, the ones on the market today are machined with a nice taper, just a quick touch with a drill bit or stone to chamfer the block guide holes to just make sure on clearance on the high lift cams is all that is needed.
- First Name: Brendan
- Last Name: Doughty
- * REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
- MTFCA Number: 15143
Re: Stipe cam
I have been running a 280 with adjustable lifters for a few years.
- First Name: Jim
- Last Name: Eubanks
- MTFCA Number: 49847
- MTFCI Number: 8340
Re: Stipe cam
Same here, I have two cars with the 280 and adj. lifters.
- First Name: Art
- Last Name: Morra
Re: Stipe cam
Well guy just what i had read thanks
- First Name: BOB
- Last Name: CASCISA
- MTFCA Number: 16897
- MTFCI Number: 16628
Re: Stipe cam
I purchased a Stipe cam when they first came out years ago.
I have had adjustable lifters from the beginning - no issues.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
- First Name: Dennis
- Last Name: P
- * REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1925 TT, 1927 Speedster, 1931 Model A
- MTFCA Number: 31449
- MTFCI Number: 24373
- Board Member Since: 2012
Re: Stipe cam
I looked at Langs’ catalog for Stipe cams. It says they “can be used with stock lifters”. It doesn’t say you can’t use adjustable lifters. I take that to mean no special lifters required. I have put in several Stipe cams with adjustable lifters with no problems.
Re: Stipe cam
I had to relieve the back side of 3 lifter bores last year, to clear a tour-grind Stipe cam (250?)
It just depends on your block. It isn't hard or even time consuming to remedy
NH Full Flow Float Valves
- First Name: Art
- Last Name: Morra
Re: Stipe cam
Thanks must mis read it i didnt think there was an issue
