Cleaning up is a good thing
Posted: Sat Oct 26, 2019 2:05 am
One of the benefits of cleaning up and organizing the shop is finding stuff you forgot you had.
I don't remember where I got this, of course, but all it needs is an adapter to fit a Model T engine.
Re: Cleaning up is a good thing
Posted: Sat Oct 26, 2019 3:44 am
by Wayne Sheldon
Looks like Christmas came early!
Make sure that hose is in good condition, and up to the task of about 80 psi and you should be good to go! Once you get that adapter.
Posted: Sat Oct 26, 2019 4:01 am
by D Stroud
I've got one just about like that Steve, I don't know where it is right now either!
Dave
Posted: Sat Oct 26, 2019 7:30 am
by Tom Hicks
Cleaning up is necessary, but I am not good at it. I tend to start a little project, have to stop for lack of materials or whatever, then go on to another project without putting the tools back because I will need them when I come back to the first project. So too many projects with tools and materials strewn around. When I can't find a 1/2" or 9/16" open end wrench I stop all projects and put all tools away. I have eight 1/2" wrenches and six 9/16" wrenches.
At least I have gotten to the point where I have a place for every tool and know where it goes, that simplifies putting them away.
Posted: Sat Oct 26, 2019 7:43 am
by Dallas Landers
When I was a kid, dad had one like that he carried in every car he ever owned. Standard equipment as was a tool box .
Posted: Sat Oct 26, 2019 8:21 am
by JunkyJud
I've often wondered if the gasoline vapor that is pumped into the tube with one of these does any kind of damage over time.
Posted: Sat Oct 26, 2019 9:04 am
by Jim Eubanks
There is no gasoline vapor pumped in, fresh air comes in thru the part that screws in to the head.
Posted: Sat Oct 26, 2019 9:33 am
We had a spark plug pump we used to pump up tires on the farm. I think it came with 3 adapters. TSC and Western Auto sold them. Do they still make them? If the plug was easy to get to it was easy to use. But when they were popular flat head engines were common so it was easy to hook one up. Not so much anymore!
Posted: Sat Oct 26, 2019 9:40 am
Yes and no. They're available with a shorter hose for use on motorcycles, but they're not made for cars. Something to do with catalytic converters.
Posted: Sat Oct 26, 2019 12:11 pm
I have one too but it is missing all the adapters.
Posted: Sat Oct 26, 2019 4:16 pm
If it has 14mm spark plug thread, you only need this adapter.
Posted: Sat Oct 26, 2019 4:44 pm
by JunkyJud
Jim Eubanks wrote: ↑Sat Oct 26, 2019 9:04 am
Ahh, that's clever. Do they work well?
Posted: Sat Oct 26, 2019 5:03 pm
by Kenny Edmondson
Not sure I buy the catalytic converter part. Most newer cars have spark plugs that you can’t get to and coils mounted direct to the plug. Also most people today would be incapable of hooking one up. Probably not enough demand.
Posted: Sun Oct 27, 2019 12:53 am
Dad used one in the Plymouth for blowing up air mattresses. I'm the guy in the striped shirt. 1946.
Posted: Sun Oct 27, 2019 8:35 am
by tmodeldriver
When using one of these adapters be sure to short out the spark plug wire while it is disconnected. Running the engine with the wire just dangling could damage the coil.
Also, I don't think the T engine is going to pump the 55 psi needed for 30x3 or 30x3 1/2 tires.
Posted: Sun Oct 27, 2019 11:17 am
I wonder if Schrader made those for Ford? I've seen them with Ford script. You could make an adapter out of an old spark plug.
Posted: Sun Oct 27, 2019 11:29 am
Well I moved mine so now I can't find it!
After looking on Ebay, knowing the size of the threads on Steve's might not help anyway. I see now there were several different types with different thread arrangements.
Posted: Sun Oct 27, 2019 12:04 pm
Bob
Jim Eubanks reply that it draws fresh air in is a clue as to how it develops pressure: the pump is a sort of accumulator pump with a smaller volume cylinder being swept by the larger volume of the piston. It's pump per sweep is much smaller than the piston, but is multiplied in pressure (compressed) for the tire fill.
Most accumulator pumps are hydraulic/air, but with different swept volumes, air/air will work too. This guy's video shows a Schrader pump and you'll see the volume of the actual pump itself:
https://www.youtube.com/watch?v=2LjbjtPR8BQ
Posted: Sun Oct 27, 2019 1:54 pm
I found mine, right where I put it after I moved it!
Mine is like the sample below, without adapters fits 18mm spark plug hole. Poop! I can find adapters to fit 14mm plugs into 18mm hole, not so much the other way.
You can buy them but the thread is wrong.
https://www.ebay.com/itm/Vintage-Sears- ... Sw5ltdh6dv
But should be an easy make if I can get to the lathe. Got more then I need of the 14mm to 1/2 pipe ones.
Posted: Sun Oct 27, 2019 2:36 pm
by dlmyers
Here's mine.
The word "Tractor" is below the Ford script.
I have no idea why the first photo posted twice. Or why the gauge photo is below the text.
Posted: Sun Oct 27, 2019 3:13 pm
by tmodeldriver
Howdy, Scott. Thanks for the explanation and video. That's exactly how a steam powered water pump can push make-up water into the same boiler it's getting the steam from. I shoulda have knowed.
Regards, Bob.
Posted: Sun Oct 27, 2019 3:39 pm
The Ford (tractor) pump is really neat! I bet that Ford pump was made in the 8-9n Ford era which was 39- 52. Could be later but not much later. The braided cloth covered hose goes way back anyway.
The fluctuating needle brings backs memories when airing up a large back tire on the back of the Ford tractor we had. It took a while and after it got aired up the plug adapter was really hot! We blew out the one we had after speeding up the engine because I thought it was to slow. Got another one from Western Auto to use when we had to.
Posted: Mon Oct 28, 2019 12:44 am
by Ken Lefeber
I saw this on the running board of an American car at the Hershey car show.
Posted: Mon Oct 28, 2019 9:33 pm
by Mark Nunn
Steve, was it beside the speedometer you were looking for?
Posted: Mon Oct 28, 2019 10:45 pm
I wish. That's still on the missing list.
Posted: Tue Oct 29, 2019 9:45 am
by Charlie B in N.J.
Cleaning up just seems to make room for more stuff.
Posted: Tue Oct 29, 2019 10:01 am
by RustyFords
Cleaning up is good. I do it about once a month and while I'm building a car, I go through my mis parts bins to remind me what I've already ordered for that car and what I need.
I'm not going to admit to how many times I've ordered the same part multiple times because I didn't remember that I already had it.
Posted: Tue Oct 29, 2019 10:34 pm
by Dennis_Brown
Go buy a 1/2 by 1/8 pipe bushing, drill it out to the proper diameter for a 14 mm tap, tap it and you have your adapter. Make 4 and use them for your spark plugs. I prefer steel pipe bushings.
Posted: Tue Oct 29, 2019 11:18 pm
by Mark Nunn
RustyFords wrote: ↑Tue Oct 29, 2019 10:01 am
I sometimes order parts months before starting a project to spread out the costs. I keep spreadsheets for both of my cars where I list parts or services purchased with "from" and expenditures columns. It helps me keep track of what I have and what I need.
Posted: Tue Oct 29, 2019 11:43 pm
by Philip Lawrence
I have been cleaning and organizing my shop and in the process so far have found enough pieces and parts to build up two more model T's.
Posted: Wed Oct 30, 2019 4:17 am
Mark, if I spent the time getting as organised as you, I wouldn't get anything done. The only spreadsheet I have is used to throw over stuff on which I don't want paint overspray. As for expendidtures, if I kept a record of those and my wife found out, well............... I much rather keep the peace than keep the records.
Posted: Wed Oct 30, 2019 8:51 am
by RustyFords
Mark Nunn wrote: ↑Tue Oct 29, 2019 11:18 pm
That is some serious organization Mark.
I work with spreadsheets at work and since my garage is a happy space, spreadsheets are a no-go
I just keep all my extras for spares down the road,
