Closed Car Windshield Removal/Replacement
Rich in Colorado
Last Name: Carlson
MTFCA Number: 50369
Post by Rich in Colorado » Sat Oct 26, 2019 4:56 pm
I have a 1922 Center Door. I have the new windshield glass, but I am having trouble removing the old glass. I cannot free the glass from the thin channel that is holding on the windshield frame.
Short of braking the glass and taking it out in pieces, anyone have a better method?
Rich in Colorado
1922 Model T Center Door
1928 Model A Tudor
1956 Ford Thunderbird
1958 Cadillac Fleetwood
Rich in Colorado
Last Name: Carlson
MTFCA Number: 50369
Re: Closed Car Windshield Removal/Replacement - Update
Post by Rich in Colorado » Fri Nov 08, 2019 1:29 pm
No one answered my post so I thought I would post how I removed/replaced my windshield. Right or wrong.
I used a 2x4 and a hammer. Put the windshield on a heavy, padded, table. Placed the 2x4 on the glass at the bottom of the frame. Tapped the 2x4 against the frame, until the glass started to separate from the frame. You have to move along the bottom edge so the glass comes out even and you don't damage the frame.
There is a very thin brass channel between the frame and the glass. It gets destroyed, but you don't need it. Keep hammering until the glass is separated.
Replace
To install the new glass, it is normal to use Fitment Tape that you could get from a auto glass place. The issue with the tape is, that the channel that the glass goes into in the frame is narrow. The tape I would have had to use was 1/32 thick. So thin I knew I would tear the tape sliding the glass down the side of the frame. So I didn't try it.
I used silicone sealant. I put the glass in the frame, then taped the glass just inside the frame. Pulled the glass back out. This way after getting the glass into the frame, I could just pull the tape and any sealant that oozed out would not be on the glass. (Or the frame, I also taped the frame off.)
I would run a few inches of sealant on the side frames, move the glass a few inches, then a few more inches, and so on until you are close to the bottom. That way you are not pushing sealant all the way down, making a bigger mess. Apply the sealant in the bottom channel, and push it completely into the frame.
Pull all the tape. Let it dry, put the end caps back on.
Rich in Colorado
1928 Model A Tudor
Mark Nunn
Last Name: Nunn
MTFCA Number: 50321
Post by Mark Nunn » Fri Nov 08, 2019 1:39 pm
Thank you for the write-up Rich. One of the windshield panels in my '26 Runabout appears to be laminated but I cannot tell what the other one is. I plan to replace that one just to be safe.
