Rear axle oil seals
Posted: Tue Oct 29, 2019 2:25 pm
by Tlitwin
I replacing the rear tires on my 26 touring. It has wire wheels. And see that one seal leaked pretty bad so was going to replace both outer seals. But should I also do the inner seals?
Thanks Tom
Re: Rear axle oil seals
Posted: Tue Oct 29, 2019 2:42 pm
by AndyClary
Yes, you need to do the inner seals also. Check the sleeves and bearings for wear since you can't deal an axle wallowing around in the tube.
Andy
