What’s the wheel puller for
Posted: Tue Oct 29, 2019 2:35 pm
by Tlitwin
The diameter is 2 5/8”
Thanks Tom
Re: What’s the wheel puller for
Posted: Tue Oct 29, 2019 2:36 pm
by Tlitwin
Forgot to add photos
Posted: Tue Oct 29, 2019 7:04 pm
Tim, whatever it fits, it is not a good design. Fine threads like that are more easily stripped when pressure is applied, and some T wheels require a good deal of pressure. A far better puller has a pinch bolt which allows the puller to be clamped down tightly on the threads once full thread engagement is reached.
Posted: Tue Oct 29, 2019 9:17 pm
by Sarikatime
That may not be a puller but a thread chaser, in case you bugger up the threads and want to fix them. Frank
Posted: Tue Oct 29, 2019 10:42 pm
by TonyB
TT rear wheel.
I know the T is 2.114” or thereabouts😊
Posted: Wed Oct 30, 2019 12:15 am
You will find that type of puller in many different sizes for many different vehicles. I think I saw about a dozen at Hershey. Unfortunately most of them don't have the clamp bolt Allan described.
Posted: Wed Oct 30, 2019 11:13 am
by Fordwright
If its a thread-chaser, it won't chase very far before the point contacts the shaft.
