New accessory item, GUESS
Posted: Tue Oct 29, 2019 4:39 pm
by Dropacent
Pretty excited about our new accessory offering. We do these things to keep busy, stay active, stay out of wifeys hair and the bar, and of course to make a buck or two. I thought I’d throw this out with a clue or three. The first to guess correctly HERE will get the first one FREE. 1) they are at the powdercoater right now, should be done in a couple days. 2) it’s an aftermarket accessory, but even the Original Smiths of the hobby MIGHT want one. 3) it’s smaller than a breadbox ( that should eliminate anyone under 50! ) First to guess correctly will get #1 FREE postpaid. PLEASE, NO EMAILS,PHONE CALLS,PMS,PMS REQUESTS, TELEGRAPH MESSAGES,SMOKE SIGNALS OR KNOCKS ON MY DOOR.
Re: New accessory item, GUESS
Posted: Tue Oct 29, 2019 4:51 pm
by Oldav8tor
Geez! How about a little clue other than size, like what part of the car it's associated with?
Posted: Tue Oct 29, 2019 4:54 pm
by Tom Hicks
Right hand henway adjuster?
Posted: Tue Oct 29, 2019 5:05 pm
by rondupree
Air filter assembly.
Posted: Tue Oct 29, 2019 5:42 pm
by Shane Lach
Is it the aluminum oil fill extensions?
by Wayne Sheldon
Hand crank anti-kickback?
Posted: Tue Oct 29, 2019 6:33 pm
by DHort
Then this post belongs on the Parts forum, since it is an accessory.
Posted: Tue Oct 29, 2019 7:37 pm
by Don D
A Gunkalator Armature
Posted: Tue Oct 29, 2019 7:47 pm
by HPetrino
Posted: Tue Oct 29, 2019 8:00 pm
by Susanne
Smith's... it's not a Form-a-Jack, is it? (Godawful screw jack things that were the scourge of british car owners in the 50's...)
I like the idea of a combo oil/water pump that runs off the mag, combined with a rectifier and regulator so you can charge a battery from the mag.
How's that? Am I close? --lol--
Posted: Tue Oct 29, 2019 8:02 pm
by Susanne
OK... Electrical, Mechanical, or Hydraulic?
Posted: Tue Oct 29, 2019 8:15 pm
by babychadwick
Based on size it would be possible to be brackets for stabilizing/reinforcing a wishbone but not the entire wishbone. Next down on size would be a battery box on the running board but thats questionable. A hand brake extension would be small enough and something I could see being more acceptable for purists.
Posted: Tue Oct 29, 2019 8:16 pm
Small - will send post paid..... >>>> Oil Sight gauge
Posted: Tue Oct 29, 2019 8:19 pm
by Henry K. Lee
Oh, Oh Mr Kotter! You have invented the perfect companion for man in a miniature size?
Horshack Hank in Tin-A-See
Posted: Tue Oct 29, 2019 8:20 pm
by Mark Nunn
Manifold cooker?
Posted: Tue Oct 29, 2019 9:16 pm
by RodellJunior
Heater.
Posted: Tue Oct 29, 2019 9:17 pm
Combination crank holder / front license plate bracket. The kind that keeps the crank handle up out of the mud
Posted: Tue Oct 29, 2019 9:38 pm
by 2nighthawks
Mechanically hand operated turn signal semaphore arm thingie!
Posted: Tue Oct 29, 2019 9:45 pm
by Tim Moore
Yup I got it! I have a few so am out. I know lots of people who don't have one. What color? Good work again Tim!
Posted: Tue Oct 29, 2019 10:12 pm
by Bob McDaniel
got to be the new coil points tool
Posted: Tue Oct 29, 2019 11:01 pm
by BHarper
Bermuda Bell?
Posted: Tue Oct 29, 2019 11:33 pm
by Philip Lawrence
It is either a copy of a original design water pump or a copy of an original firewall mounted Marvel Mystery Oil reservoir with all fittings and tubing to hook up directly to the engine.
Posted: Wed Oct 30, 2019 12:35 am
by KWTownsend
Hand brake extension handle.
Posted: Wed Oct 30, 2019 12:49 am
That was going to be my guess too.
Posted: Wed Oct 30, 2019 1:08 am
by Novice
Emergency axle. Cable operated brake equalizer.
Posted: Wed Oct 30, 2019 6:37 am
by aDave
Brake Light
Posted: Wed Oct 30, 2019 7:08 am
by Doug Keppler
A non vibrating side view mirror
Posted: Wed Oct 30, 2019 7:39 am
by Banjoe
I don't have one, but it's powder coated and just in time for Christmas, so I really need this......... whatever it is.
If I have to guess, I'll go with an air foil to keep the rear of the car fixed on the ground at high speeds.
Posted: Wed Oct 30, 2019 7:56 am
by JimDix
Suicide door coupe sun visor.
Posted: Wed Oct 30, 2019 8:00 am
by Dallas Landers
If Larry would even like it, must be small cans of 100 year old air for the tires. Where did you ever find the air Tim?
Posted: Wed Oct 30, 2019 10:54 am
by John Codman
I hope that it is the shake-free mirror. If it is, I will order one.
Posted: Wed Oct 30, 2019 1:53 pm
by david_dewey
Hmm,the only thing I can think of that Larry would use (and mostly because CA state law says we should have one) is a driver's side rearview mirror.
Will be interesting to find out what it really is!
Posted: Wed Oct 30, 2019 2:05 pm
by Quickm007
Battery box!
Posted: Wed Oct 30, 2019 2:43 pm
by modeltbarn
Fuel Gauge?
Posted: Wed Oct 30, 2019 8:28 pm
by Bmettli
Lol.
Variable valve timing
Emission controls
Dashboard Totally integrated power modules (TIPM)
Limited slip thrust washers
E85 compliant carbs
The possibilities are endless.
Posted: Wed Oct 30, 2019 8:33 pm
by Les Schubert
Brian
I have thought about doing variable valve timing. The concept has merit!
Posted: Wed Oct 30, 2019 8:50 pm
by Dropacent
I had to go slowly through all the great responses. Nobody has got it yet. Lots of great ideas, but so far only Timmy Moore knows,so he will get #2 gratis. Oh, by the way Tim, they will be any color you want as long as it’s black! That’s clue number 4. #1 is still reserved for the right answer posted here.
Posted: Wed Oct 30, 2019 9:02 pm
Hogs head oiler like the ford Faithful oiling system.
Posted: Wed Oct 30, 2019 9:18 pm
by Pep C Strebeck
An early screwdriver for the tool kit?
Posted: Thu Oct 31, 2019 10:20 am
Spring loaded oil can holder
Posted: Thu Oct 31, 2019 10:27 am
by henryford2
Dan, did you get some inside help?
BINGO ! Dan is the man !
Posted: Thu Oct 31, 2019 10:58 am
by Dropacent
Bingo ! Dan will be getting one in the mail. A faithful reproduction of a spring loaded oil can holder. Just recd a message they are ready to snag at the powdercoat, so will post a picture of our new baby. Later ,a full spiel will be posted in the classifieds. Thanks for all the great guesses , maybe some new ideas for others. AND , if Original Larry Smith would even use one, I’ll send him one free, too. HAPPY HALLOWEEN !
Posted: Thu Oct 31, 2019 12:02 pm
Nope, no ‘forum leaks’
This forum ain’t like DC!
Just serious thoughts on a desired accessory many T owners would like or need to like as the oil can came with the car’s tool set and no place to store it other than garage shelf. The last guess of the screwdriver with the earlier tool kits made my brain fart happen!
Thanks Tim!! Will use that accessory, now thinking best spot to drill holes in the firewall
Posted: Mon Nov 11, 2019 9:23 am
Got my
Major Award last week from Tim.
What a great accessory! Tim did a terrific job of recreating the spring loaded version of the firewall mount oil can holder.
The spring is good and strong, can won't work loose and holds firm.
Thanks Tim! and thanks for offering these to others, will put mine to use
