MAGNETO POST WITH OUTSIDE OIL LINE CONNECTION
Topic author - Posts: 177
- Last Name: Dow
- MTFCA Number: 32344
Can anyone tell me where I can find a 3 screw magneto post with the external oil line connection? Mine works intermittently and before I try to fix it, I'd just like to just buy a replacement. Thank you.
- First Name: Bill
- Last Name: Anziani
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
Re: MAGNETO POST WITH OUTSIDE OIL LINE CONNECTION
Smith and Jones has them 803 822-4141
- Last Name: Dow
Thanks Bill. I call them tomorrow but it looks like they carry the post without the oil line connection like all the other suppliers I've checked.
- First Name: Nikolaus
- Last Name: Martin
- MTFCA Number: 32342
- MTFCI Number: 23512
Here's the one from Lang's. https://www.modeltford.com/item/3082OL.aspx
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
By curiosity which outside line is the best option?
"Ford Faithful" Ouside Oiler Kit?
High volume outside oil line kit?
MAGNETO POST WITH OUTSIDE OIL LINE CONNECTION KIT?
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- MTFCA Number: 28924
Whether or not if you use an outside oiler it’s a good idea to use the oil filter screen that fits under the transmission cover door.
Lang’s, Snyder’s, Smith and Jones all carry the mag post oiler. I have the mag post oiler on my T’s along with the transmission oil filter and they work fine.
- Last Name: Dow
Thanks everyone. I can get the post with the outside oil connection IF i buy the whole kit. I only need the post not all the other plumbing.
John
the only extra thing you'll get with a kit, is the copper line and the fitting on the front of the engine. When it breaks and you're a long way from home, you may wish you had a spare.
NH Full Flow Float Valves
