Ford history questions
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Thu Oct 31, 2019 4:05 pm
Henry Ford was already entering middle age when he began to experience his astounding success with the automobile, but I'm unclear if some things were myth or reality. Did he forbid a driver's door on the Model T because he believed it was unsafe for the driver to stand on the left side of the car in traffic? I know some export cars had driver's doors, including those in Canada, but I don't know if it was due to different regulations, or just consumer demand. Maybe Ford cared less about the safety of drivers in other countries. He refused to adopt the modern high-tension coil ignition and distributor until 1928, which had appeared on other cars since 1910. He was content with the old "buzzbox" ignition, used since around the turn of the century driven by first dry cells and later a low-tension magneto. He retained this old type of ignition even after he upgraded to an electric starter, a generator and rechargeable storage battery in 1919.
One story has it that Henry constantly tormented and denigrated his son, Edsel. When Edsel developed a new prototype car to impress his father, Henry took a sledge hammer to it, smashing it to bits. He obviously felt threatened in some way.
It's been said that Ford might have continued with the Model T long after it had gone out of favor, had it not been for intense pressure from his family and associates to upgrade to a newer model. He is supposed to have said, "There's nothing wrong with the Model T except that people aren't buying it."
Also, when the new Model A was introduced in 1928, the story is that he forbid the use of hydraulic brakes, because he claimed "they always leak." He insisted on using only one spring per axle, as with the Model T, and when he experience a very rough test drive, he decided to install shock absorbers on the Model A. A six-cylinder engine might have been a reasonable upgrade for the Model A, but Henry's competitiveness caused him to spend a fortune developing the V-8, which was a success, but not as well-received as it could have been, owing to the fact that it was more engine than the average consumer needed at that time.
He was approaching his 70s by this time, and some were saying he should step aside. That didn't happen until years later, and under pressure from his family. I won't go into the way he treated his labor force, or his anti-Semitism, because those are broader subjects for other discussions.
bud delong
First Name: Kenneth
Last Name: DeLong
Re: Ford history questions
Post by bud delong » Thu Oct 31, 2019 4:31 pm
I do not think Edsel had anything to do with the replacement for the model T in 1911 or 1912. :D Bud. :D
Will_Vanderburg
First Name: William
Last Name: Vanderburg
MTFCA Number: 28382
Post by Will_Vanderburg » Thu Oct 31, 2019 4:54 pm
Edsel Ford was only 19 in 1912, so highly doubtful he had a plan for replacing the Model T then. He didn't become president of Ford until 1919.
The story about the sledgehammer is fictionalized for the movie "Henry Ford: The Man and The Machine". Cliff Robertson beat a prototype with a sledgehammer. The story goes that Henry tore the car apart with his bare hands and kicked it into submission. The sledgehammer story is perpetuated in a 2012 book called "American Icon".
Henry Ford only acquiesced to making a new Model A because of dwindling market share.
And I highly suspect Henry was loosing his faculties earlier than people think.
William L Vanderburg
1922 Center Door Sedan
Will_Vanderburg
First Name: William
MTFCA Number: 28382
Post by Will_Vanderburg » Thu Oct 31, 2019 4:58 pm
When Henry Ford finally stepped aside, it was inevitable that President Roosevelt was either going to take it over and force Henry to resign or install his grandson as president, because by that time I seem to recall the company was loosing 10 million a month. So the call was made to remove the grandson from the US Navy and run the factory. Probably a wise decision.
BobD
First Name: Bob
Last Name: Doris
MTFCA Number: 32538
Post by BobD » Thu Oct 31, 2019 5:03 pm
Same here, I have a hard time wrapping my head around this. Why didn’t Henry go with the “single spark system” when the starter cars came out in 1919? Think of the savings in cost of materials and labor. Only one coil, one set of points, ease of serviceability, not to mention the magnets and ancillary parts in the flywheel magneto assembly. Would have been minimal casting changes or could have been a bolt on type distributor not unlike the aftermarket offered at the time. What am I (or we) missing? :?:
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Oct 31, 2019 5:55 pm
One should keep in mind the cost and reliability of early batteries, as well as the remote non-electrified majority of the nation. These cars when new, needed to be self reliant... as possible. As for maintenance, simple mechanics are capable of fixing simple mechanics, so keep em simple! And don’t forget that ol’ Henry would have had to pay royalties to Bosch/Prestolite/or god forbid Delco to change the ignition
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Thu Oct 31, 2019 6:02 pm
Bob
Likely Henry stayed with the flywheel and trembler coils after the starter and battery lights era for the fact of his T being a ‘non-pre- obsolescence’ vehicle. i.e. he strived to keep changes to the T minimal, for factory benefit, customer, and dealer parts supply repair chain, if a major part had to change, most every time it could retrofit with ease. No upsetting the sales or service.
When an ALL new Ford arrived it did have the latest of design to the ignition, but the hand crank was still in place albeit removeable :P
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Thu Oct 31, 2019 6:41 pm
Bob
Likely Henry stayed with the flywheel and trembler coils after the starter and battery lights era for the fact of his T being a ‘non-pre- obsolescence’ vehicle. i.e. he strived to keep changes to the T minimal, for factory benefit, customer, and dealer parts supply repair chain, if a part had to change, most every time it could retrofit with ease. No upsetting the sales or service.
I don't think ignition systems were in Henry Ford's skill set. The story goes that he won his first race against the reigning champion, Alexander Winton in 1901 using dry cells and breaker points inside the combustion cylinder. One of his star mechanics, Ed "Spider" Huff made up a sparking coil and timer using spark plugs of the type that had already been in use since before the turn of the century on things like donkey engines. Henry Ford was said to have been so impressed that he had no desire to improve on that system until the Model A in 1928. It's said that Henry Ford asked Spider Huff to design the new ignition system for the Model A, but he gave a rather jaded response, saying that Henry "would never be happy with it no matter how he designed it." But much or such history is probably based on hearsay and imperfect memories to be sure.
bud delong
First Name: Kenneth
Last Name: DeLong
Post by bud delong » Thu Oct 31, 2019 7:15 pm
I think most of the true story is for us to see at the Benson Ford and the actual facts will come to light! :D Bud. :D
Post by Wayne Sheldon » Thu Oct 31, 2019 7:21 pm
Crank starting? Not just Ford. In fact, I think Chevrolet outdid Ford by a lot! I don't know when they stopped including the hand crank with new cars, but they were available at any auto supply store, and nearly every garage mechanic had one. Chevrolet cars were equipped with the ability to be hand cranked at least until 1939 (I think the '41 my dad had when I was really little still had the ability?). Trucks, pickups up to two ton continued to be equipped for hand cranking at least until 1952! They came from the factory with the directional engagement on the crankshaft pulley, and a pathway under the radiator and through the grill for the hand-crank.
I think Ford dropped the hand-crank along with dropping the four cylinder in trucks. The V8 was a bit much to try to crank by hand. I am not really sure about that, I never have had much to do with Ford's early V8s. Too modern to really interest me. I do know that some European Fords with their smaller engines continued to have hand crank capabilities even after WWII. And some European and English sports cars continued to be hand cranking equipped even through the 1960s.
I seem to recall a few Chrysler products having hand cranking capabilities in the late '30s. But I am no expert on Chrysler products of those years.
MTFCA Number: 28924
Post by John kuehn » Thu Oct 31, 2019 8:43 pm
As far as tractors go Ford tractors had hand cranking ability along with electric start thru 1954. I have a 54 Ford NAA tractor and it can be hand cranked if need be. Not sure when hand crank capability was dropped but pretty sure it lasted longer than 54. I would imagine other tractor makes did also.
bud delong
First Name: Kenneth
Last Name: DeLong
Post by bud delong » Thu Oct 31, 2019 9:00 pm
The book Tin Lizzie by Stern will tell you who was involved in trying to put the car into production that Henry wrecked with his bare hands and feet in 1911 or 1912.It will also tell of cancelling orders for bodies and other large parts.I cant recall ever reading anything about Edsel being involved.The story has a special interest for me because our 14 has a Cleveland Hardware front axle. :D Bud. :D
Post by Mark Gregush » Thu Oct 31, 2019 9:06 pm
Canada was building cars for domestic (both right and left)and export to countries that were right hand drive. I was easier to just build one body with doors on both sides. Canada, depending on the area, was ether left or right hand drive.
1920 Dodge touring
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Thu Oct 31, 2019 9:16 pm
IMO, just the opposite. Henry first gas engine, the kitchen sink one, began his knowledge of igniting gas engines, he made lots of contributions, the most famous in directing Huff to perfect his idea of a low tension magneto that would need no owner maintenance. High tension magnetos of the day used outside power to drive, needed points cleaned and regular care and oiling, could succumb to moisture and dirt.
So his direction made the Model T ignition superior of the day, no service issues, 4 individual coils too, if one went south you came home on three cylinders, not onboard old Dobbin ;)
Huff worked for Henry, used Henry’s direction, added his own efforts, and Ford secured a patent, with Ed Huff as novel inventor, for a magneto to be contained within Ford’s engine, with the patent gained by Henry and then assigned to Henry.
This contribution by them put the simple reliable ignition system in the Model T, 15 million of them, and unknown thousands of these Fords are still on Ford/Huff system! Like today’s Coil -on -Plug technology, 1908 style.
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Thu Oct 31, 2019 9:43 pm
I've seen plenty of larger trucks and tractors that had provision to attach a hand crank, but I can't imagine some of those engines being hand started. I assumed it was for turning the engine for some types of engine maintenance work like setting the timing.
Post by Mark Gregush » Fri Nov 01, 2019 12:40 am
My 48 F3 with 6 cylinder has the crank provision. I have tried it, no way could I crank to start, but works great for setting timing etc.
1920 Dodge touring
rickd
First Name: Rick
Last Name: Duquette
MTFCA Number: 21848
MTFCI Number: 22173
Post by rickd » Fri Nov 01, 2019 8:24 am
Greg, regarding your question on the lack of a drivers door on the Model T; IMO it was mainly related to the infrastructure situation of the day. Almost all roads were either gravel or dirt and the sidewalks in business and residential areas were developed first, and started as wood platforms and then eventually concrete. It was easier to stay out of the mud stepping out of your car on the passenger side. Probably also safer as I imagine the rules of the road were a little sketchy at the time.
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Fri Nov 01, 2019 10:42 am
I'm not so sure about the driver's door(or lack of same) explanation. I have a 1917 touring and there are doors on both sides of the passenger compartment. I always assumed it had more to do with the difficulty of climbing in an out with the lever, wheel and pedals in the way. Canadian cars had doors on both sides as explained above. Don't forget, Henry was cheap - probably saved money by not putting in a real door :D
1952 Willys M38a1 Jeep
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Fri Nov 01, 2019 12:06 pm
Although most replicas use spark plug ignition, Henry Ford's original 1893 "Kitchen sink engine" got it's ignition from the light bulb socket hanging over the sink. It most likely consisted of breaker points inside the cylinder, using the light bulb as a current ballast. Henry Ford worked for the Edison Illuminating Company of Detroit at the time, but not as an electrical engineer. His talents were almost exclusively mechanical.
But he did recognize a rugged and reliable design, the trembler coil being one, which he had little interest in modifying over the production span of the Model T. But in all fairness, the high-tension magneto had been used in production cars since 1899, and by 1919, nearly every car on the market was driven by magneto ignition. By the time the Model T went into mass production in 1913, a magneto still cost around $140, which was completely out of range for the Model T.
If Ford had wanted, he could have modernized the ignition system to the high-tension magneto type when he added an electric starter, a generator and a storage battery in 1919, as he could have lowered his costs by manufacturing his own magnetos and simplified the electrical system by elimination of the low-tension flywheel magneto and the four trembler coils. This again, suggests Henry Ford's unwillingness to get involved with ignition systems.
rosenkranswa
Last Name: Rosenkrans
MTFCI Number: 22021
Post by rosenkranswa » Fri Nov 01, 2019 1:42 pm
My 1942 Ford Sedan has provision for cranking. You had to order an extension bar and handle from the dealer to use it, and I have tried turning the engine over with the crank with quite a bit of resistance. I can't imagine cranking a V8 to start it, but it might be possible.
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Fri Nov 01, 2019 1:58 pm
Our 1950 LA Case tractor had a crank on the front and magneto ignition, but it also had electric start. It had quite a large engine for the times which was over 400 cubic inch. I can't remember anyone starting it with the crank, but it must have been possible. Booster cables were always the best option if the battery were dead.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Fri Nov 01, 2019 2:43 pm
Remember we are discussing the Low price Ford ;) A car made for the masses, easy to repair at low cost, there wasn’t desire for Henry to complicate the Ford T success. He even continued to offer non-starter car to near the end of the T’s production. High-tension magnetos require care and service, the Ford flywheel magneto was simple with no owner upkeep.
Besides, a bit of primary research easily shows only high price cars in 1919 had high-tension magneto ignition, the majority of autos and trucks in the USA used battery spark ignition. Autos such as Case, Chandler, Locomobile, Marmon, and National used Bosch or Eiseman units, by far over 60%* of the 538 listed cars and trucks from 1913 to 1920, in a publication of period wiring diagrams used Delco, Remy, or Westinghouse battery ignition units.
* Wells, Automobile Wiring Manuals, [/i]1920.
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Fri Nov 01, 2019 3:41 pm
You may be right, but there was plenty of time between 1919 and 1927 for Ford to come up with something more efficient and cost effective than a system comprised of: a flywheel generator, four trembler coils, a starter, a generator and a storage battery.
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Fri Nov 01, 2019 6:29 pm
Another example of Henry Ford's stubbornness in his later years was his insistence that engines not have oil pumps, only splash lubrication. When the V8s were being developed, they all burned out on the test stands until oil pumps were added.
As mentioned, he opposed hydraulic brakes, forbidding them until Edsel added them in 1939. He also believed four-wheel brakes were dangerous and had them installed only on the rear wheels.
bud delong
First Name: Kenneth
Last Name: DeLong
Post by bud delong » Fri Nov 01, 2019 7:50 pm
So after 4 years of the model A with a oil pump Ford did not start with them in the V-8?? Bud. :D Many engines had combination of splash and pumps into the 50's.
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Sat Nov 02, 2019 12:04 am
That's what the sources say. At least we know that the V8 was tried with splash-only lubrication, but failed to make it past the dynamometer test without piling up.
BuddyTheRoadster
First Name: Chris
Last Name: Rini
Post by BuddyTheRoadster » Sat Nov 02, 2019 5:48 am
You bring up a lot of good questions, and I'll try to address them in the order posted.
Henry Ford was a complicated man (as was his buddy Thomas Edison) and he had some contradictions that seem odd to us now. Now there are three things to remember: 1) the Model T was almost always the cheapest car on the market, it was consistently cheaper, smaller, and more spartan than Overland, Chevrolet, Star, or Gray. 2) Henry Ford had a confidence that bordered on arrogance, and if you weren't in his closest circle, you didn't criticize anything about the Model T or the factory if you valued your job. 3) Ford died of a cerebral hemorrhage and had suffered several "cardiac events" previously. If these were strokes, it's likely his personality changed dramatically.
No driver's door
I think it was a combination of economy and social behavior. A driver's door means one more door and components per car, and you've got the hand brake lever in the way. This would save a little money per car, and bodies would be a little better braced without it. Socially, I think it was normal to enter a car from the passenger's side. I've heard in some cities it was illegal to enter from the driver's side, and look at how late it took for enclosed cars to get an outside door lock on the driver's side.
Vibrator coil and magneto
Vibrator/trembler/buzz coils were typical when the T was designed in 1908, but mating them with Ed Huff's flywheel magneto was genius. It's a self-contained ignition system that doesn't rely on telephone batteries like most cars of the era. And it works darn well if everything's healthy. I bet Henry stuck with it because 1) the T was his baby and it was "perfect" and 2) using a conventional distributor would mean a concession that Charles Kettering and Delco had a good idea, and Henry was too proud or cheap to admit it. As it was, Ford was almost the last to get electric lights or a starter.
Henry and Edsel
All fathers and sons have some drama. Henry and Edsel, although close, were temperamentally opposite. Henry was a Michigan farmer, I think he liked being scrappy. Edsel by all accounts was kind and peaceful. He lived well and had great taste. Although Edsel was the president of Ford Motor Company from 1919 on, Henry called all the shots.
Producing the Model T forever?
The Model T was Henry's baby, he thought it was the perfect car and had everything you needed. Why would one need more? If it didn't sell, then it was dealers' fault for not doing their job. When you look at production figures and see the dramatic decline from 1923-1926 and the rise of Chevrolet, you can see what was happening. But no, Henry thought that a new body, color paint, and factory authorized accessories was all you needed.
No hydraulic brakes
I've heard a story that Edsel had 10 Model As equipped with hydraulic brakes, lined them up, and then said, "Dad, drive any one of these and see," and the car Henry chose had a leak and the test driver wrapped it around a pole. I bet the reality was that: 1) Henry and the engineers who agreed with him were conservative and didn't trust hydraulic brakes, and 2) they weren't going to pay any patent royalties. (Maxwell-Chalmers used Lockheed patent brakes in 1923 but didn't like the design. They reworked them, showed Lockheed the improvements, and Lockheed adopted them in exchange for waiving royalties. When Maxwell-Chalmers introduced the new Chrysler car in 1924, guess who got free Lockheed brakes? Incidentally, the initial Lockheed patent would have expired in 1937, right about the time that everyone finally converted to hydraulic brakes.)
Why not a six?
The conventional wisdom is that the "failure" of the 1906 Model K put Ford off of six cylinder cars for the rest of his life. I think the real answer is that practically every four cylinder car in the 1920s moved up to a six, and Henry refused to be a trend follower. Look at his experimental X-8 program. That was just weird, but no one could upstage that if it had worked.
Now, I love automotive history, and I love wondering about the "what ifs." What I wonder is what would have happened if Ford hadn't fired Bill Knutsen in 1922, and if Chevrolet had foundered instead? Also, what if Henry had listened to Ernest Kanzler instead of firing him in 1926?
dykker5502
First Name: Michael
Last Name: Deichmann
MTFCA Number: 29116
Post by dykker5502 » Sat Nov 02, 2019 5:52 am
After the troubles with the Selden patent, Henry Ford saw (others) patents as a way to put roadblocks for his enterprise.
Hydrailic brakes was patended in 1922 +/- and lasts 17 year so that is why hydrailic brakes first arrived in 1939.
And regarding the trembler coils - why change something that worked? And there may be patent issues as well.
Ford Model T 1914 Touring
ECCT, Strobospark, HCCT, Rebuilding coils
Banjoe
First Name: Joe
Last Name: Lucas
MTFCA Number: 50498
Post by Banjoe » Sat Nov 02, 2019 8:12 am
The collective wisdom here is pretty impressive and is generating a fascinating discussion. Thank you to all contributors.
None of us is as smart as all of us.
BobD
First Name: Bob
Last Name: Doris
MTFCA Number: 32538
Post by BobD » Sat Nov 02, 2019 12:04 pm
Is is possible that when the Model A was being developed in 1927, the unique distributor design and certain patents expiring led to the adoption of the “single spark system” in the Model A?
Post by Mark Gregush » Sat Nov 02, 2019 12:31 pm
Some Model A's have Bosch made distributor bodies. While somethings about it are Ford, there are things like the point setup that had been used on other brands. The cable that runs from the switch to distributor, was like what other car makers were using at the time. GM's ran off the back of the coil but as I recall were the same brand name.
1920 Dodge touring
BobD
First Name: Bob
Last Name: Doris
MTFCA Number: 32538
Post by BobD » Sat Nov 02, 2019 12:59 pm
Interesting regarding the Bosch made distributors. As a former “A” owner, I did not know that detail.
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Sat Nov 02, 2019 1:24 pm
The flywheel magneto which was actually an alternator, was originally a brilliant solution for driving the trembler coils, but by 1919, after a generator, a battery and starter were added, it was a bit of a kluge, which could have been simplified, even if just by losing the flywheel magneto. Ford could easily have upgraded the ignition to something simpler and less expensive, but as mentioned, it was a very autocratic organization and Henry never showed much interest in electrical systems.
otrcman
First Name: Dick
Last Name: Fischer
Post by otrcman » Sat Nov 02, 2019 2:15 pm
I'm certainly no magneto expert, but it has always seemed to me that Ford's flywheel mounted magneto embodied sublime synergy (take that for allitteration, Bob Coiro).
Consider these factors:
1. To produce adequate electrical output from a magneto, the magnet must be moved rapidly past the armature. The more rapid, the higher the output. If the magnet(s) are arranged in a small circle, they have to be spun really fast. But hand cranking produces only low RPM. So what's the alternative ? Simple. Make the circle larger and put the magnets at the outer edge of the circle. And where do we find the largest rotating circle in an engine ? On the flywheel ! Since he had to have a flywheel to smooth out engine operation, why not get. a free ride for his magneto parts at the same time ?
2. To be sufficient on a four-banger, the flywheel needs to be pretty heavy, with its mass concentrated as far from the center as possible. Rather than buying more iron for a heavier flywheel, is there any metal that already had to be on the car that could be used for weight ? How about that big pile of iron magnets ?
3. As engine RPM increases, it takes more and more voltage to fire the spark plugs. Well, coincidentally, the magneto produces more and more voltage as the RPM builds up. Battery ignition systems run a constant voltage, so ignition performance suffers at higher RPMs. Not so with a magneto; higher voltage appears at the very time the spark plugs need it the most.
4. In the age of dry batteries only, you ran out of sparks when the battery went dead. So you were range limited not only by your supply of gasoline, but also by your supply of batteries. With magneto ignition, your electricity supply was derived from gasoline. So your consumables were reduced by one item.
Ford seemed to be a man fascinated by simplicity, economy, and effective use of materials. I think he just loved the flywheel mounted magneto ignition. Of course later developments such as rechargeable batteries, engine driven generators, advanced materials for breaker points and distributor contacts, etc, made the magneto virtually obsolete. And Mr. Ford was slow to embrace innovation that wasn't his own.
I bet he spent a lot of time thinking about perpetual motion !
bud delong
First Name: Kenneth
Last Name: DeLong
Post by bud delong » Sat Nov 02, 2019 2:24 pm
As someone stated above the rural country was not ready for a non self sufficent auto in 1919. Ford sold millions of Model T's after the advent of what some would call modern ignition and self starters.Some early autos had built in air compressors and air starters but they faded fast with better roads,tires,and the advent of the battery starter,and generator. Don't fret as why not,Ford sold 15,000 000 plus! Bud. :D
Jeff Hood
Last Name: Hood
MTFCA Number: 25636
Post by Jeff Hood » Sat Nov 02, 2019 2:55 pm
As far as the car not having a drivers door, it was probably considered unnecessary due to the brake lever, pedals, and steering wheel interference. There was drivers side access on earlier cars without doors, and there was a left rear door on later touring bodies too. Also as mentioned, if driving in the city where there were sidewalks or boardwalks and dirt (or mud) streets drivers were more likely to exit the passenger side and many places had ordinances against exiting on the traffic side. Many of these ordinances are probably still on the books but largely ignored. If you watch old movies or TV shows, you will often see drivers slide across the seat and enter and exit the passenger side, even into the 1960's. My 1956 Ford F100 pickup only has a key lock on the passenger side. Lock the drivers door from the inside, slide across and exit the passenger side and lock with the key.
Jeff Hood
Last Name: Hood
MTFCA Number: 25636
Post by Jeff Hood » Sat Nov 02, 2019 3:14 pm
Ford felt that his car provided everything that anyone would ever need. It was simple, reliable, economic transportation that anyone could afford. He said that he would "build a car for the masses" and he did, and he sold 15 million of them. He also said that as long as a Ford car was on the road, an owner could secure replacement parts. He wasn't thinking about replacing the cars he had already sold with new ones, he was still selling new customers the car that he felt was all that they would ever need. It was Billy Durant who realized he could generate more sales by making changes that would make people want to buy the latest style or color or move up to a nicer or more luxurious or prestigious car. That's likely one of the reasons that the Model A was a big success. It was a HUGE improvement over the Model T, as was the 1932 car an improvement over the A. After that and with Edsel's influence, Ford began almost yearly styling changes to attract new customers.
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Sat Nov 02, 2019 3:41 pm
When it was introduced, the flywheel magneto in combination with the trembler coils was a brilliant solution. The magneto produced unregulated AC current that varied considerably from 4 volts to over 30 volts at higher engine RPM. The trembler coils acted somewhat as a ballast against too much current, and had to be built robustly in order to handle the fluctuating power, and there had to be four of them.
Certainly, Ford could have simplified the ignition system after 1919, shaving even more off the cost of the car. A single coil has proved itself reliable for over 50 years, and a high-tension distributor with a single set of points is a design at least equally robust to the what the Model T stuck with throughout. As far as patents, they were never a problem for Henry Ford when he set himself to working around them. He simply wasn't much of an electrical engineer.
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Sat Nov 02, 2019 3:48 pm
Funny how things have changed. My car has only one keylock and it's in the driver's door.
First Name: David
Last Name: Hjortnaes
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Sat Nov 02, 2019 7:07 pm
What year was the first year without a driver door?
Trentb
First Name: Trent
Last Name: Boggess
Post by Trentb » Sat Nov 02, 2019 8:21 pm
1908 was the first year Model Ts were produced without a driver side door.
A more useful question is what was the first year in which Model Ts came with driver side doors. The answer to that is the 1911 enclosed runabout, aka torpedo.
Respectfully submitted,
Trent Boggess
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Sun Nov 03, 2019 2:53 am
The style of some coaches prior to those days didn't have doors, because the sideboards were often low enough for the driver to step over. Doors were sometimes installed for passengers who were generally of a higher class than the driver and/or ladies who might find it undignified to step over the side. The Ford Model T coach builders may have carried some of that tradition forward.
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Sun May 24, 2020 6:02 pm
i hope this isn't too far off-topic, but there seems to be little written about Ford's aviation contributions. He basically kickstarted commercial aviation with his Ford Trimotor airliner, but after a blockbuster success in the mid-1920s, he wrapped it all up in 1932. By that time McDonnel Douglas had developed the DC-1, soon followed by the DC-2, and the iconic DC-3. The fledgling airlines he helped get off the ground, and couldn't buy enough Ford Trimotors, then deserted him in droves once a better airliner became available.
It's a bit like a repeat of his Model T experience, where he tried to sit on a proven design, making very few developmental changes, for far too long until the competition passed him by.
Post by Norman Kling » Sun May 24, 2020 7:20 pm
Without the ability to read one's mind, I guess it is only speculation as to why Henry did the things he did.
I do know this that Henry wanted to make a car which could be mass produced and so he was reluctant to make changes unless they were true improvements. Whether or not the door was eliminated for structural strength or not is speculation. Those cars did have back seat doors on both sides, so the easiest idea to believe was caused by two things: the ease of entry and exit into the driver's seat, and economy of saving a few dollars by not constructing the door. The last two years of the T's actually had doors on the driver's side but very hard to get the foot behind the brake lever while the knee is under the steering wheel and buttocks over the door post. Even the earliest Model A's had the brake lever on the left, but was later moved to the center which made it easier to get in and out and since it had the center gear shift the brake was in front and later to the side of the shift.
The starter was added later because of competition. But when Henry added something, he left the old method for those who were set in their ways. The starting crank remained. The ignition could be run on either battery of magneto. Later when the Model A came out with the foot accelerator, the column gas lever was still in place. So the only new thing you really needed to do was learn how to shift the gears.
I once had a 1929 Chrysler which had hydrolic brakes, but it also had mechanical mechanism to operate the rear brakes if you pushed hard, so there might have been some truth in the unreliability of hydrolic brakes.
Until the voltage regulator was added to the charging system it was really a good idea that Ford continued to have the availability to crank the engine. If you set the generator high enough to run the lights, it would overcharge the battery with the lights off, and if you set it to charge less with the lights off, it would run the battery dead if you drove all night. I remember driving from Yuma to Las Vegas in a Model A with lights on, and when I got right to the intersection of Fremont and Los Vegas Blvd. I stopped at a signal. The generator didn't put out enough to idle with lights on and I killed the engine. I had to get out and crank. Fortunately I had a crank and it started with lights off. I was able to get to our Motel for the night. Also I have had a few early V8 closed cars and they had the key lock on the door on the curb side, so had to lock the driver's door and then lock from the curb side.
George Mills
Last Name: Mills
MTFCA Number: 29497
MTFCI Number: 10032
Post by George Mills » Mon May 25, 2020 8:52 am
One of the biggest sacrilege to Ford history is the claim that Henry was too stubborn to give it a rest, and that once one of his prized employees jumped to Chevy that Chevy busted Fords butt in the market.
I think all of those as singular statements are probably true...yet Ford themselves chose to bury the story of the Model X which could be fascinating if someone knew how to research and make a story.
The X had it worked and made it to production, would have skunked everybody as from tid-bits I’ve gleamed over the years seems like the X was expected to be ready 23/24-ish. The body design was done as a drawing of it does exist and surfaces every now and then...and very remarkable a lot of its styling wound up on the so called knee jerk decision to make the improved body.
A grad student at the Henry Ford maybe 15 years ago turned up the day book journal of one of Henry lieutenants that reports failure after failure of the radial engine to be stable enough, as I’ve seen that referenced in one of the books (5$ day??? The American System??? One of those soft cover grad thesis spun off as a book)
Rob recently was able to prove pretty much beyond a doubt that Ford buried the Model K true story in spite of historical claims it was a dog and a Malcomsen thing. Someday, maybe someone with equal passion will gnaw on the Model X and find that Henry was in favor of the project...that it was tasked to Lieutenants and it just never came together. ( possibly could be the answer as to why he personally pushed his lt. aside on the Model A and said All Me!) Then again, it may have been a red herring looking for a rabbit hole to blunt Knudsen input at Chevy? As they say....history belongs to the power of the scribe!
Yet it would be nice for the missing chapter to be restored.
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Mon May 25, 2020 5:58 pm
A lot of people forget that most of the midwest, except the big cities, did NOT have electrical power until during the mid- 1930's when the Rural Electrification Administration put electricity everywhere in the U.S.
If you had a car with a battery, and it failed, and you were somewhere in North Dakota, you were both literally and figuratively screwed.
If you read the "Fordex Sales Book" for 1926, they are still told to stress that "The Model T is completely independent of battery needs. A battery failure on a Model T has no affect on the operation of the car. It is not necessary to have access to a battery service facility if you own a Ford."
Considering the short life of batteries back then, and the relative reliability of the Ford flywheel generator system, I'm sure there were a lot of people in isolated areas who were glad they had a Ford Model T.
Park it for the winter in the barn, and when the snow melts in the spring and the roads are back open, crank it up and off you go.
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Mon May 25, 2020 6:02 pm
Susanne
First Name: Susanne
Last Name: Rohner
MTFCA Number: 464
Post by Susanne » Mon May 25, 2020 7:06 pm
People don't understand the rural US of the 20's and 30's are not like America today.
I have friends who grew up in rural America in the 1950's with outhouses and Kerosene lanterns and stoves... because they didn't have electricity.
Deciding to base an automotive ignition system on something that did NOT rely on batteries, even to the 40's, was huge. The flywheel AC generator was a Godsend as it allowed a car that was not tied to batteries. Even after Ford moved beyond his multi-decade love affair with an AC ignition, he still enabled his cars to run without a battery... as did most manufacturers. It was only the advent of the "alternator" which changed that...
A ford T, marketed mainly to the rural masses which Henry understood and considered "his" people, needed to run on any fuel available with nothing else holding it back, like the need for something like a battery. And his tractors running the same antiquaed system plowed many a field...
There's a whole bunch of electrical and electronic engineering involved with the Autosynchronous Coil (which was named that because the 3 magnet pulses gave multiple impulses to spark ignite whatever a farmer could scrounge - try it today, get some gasoline that's been sitting years, and I bet your T will run on it - rather than the one spark system others used. But the even cooler aspect was those magnet pulses were just as timed to a motor and it's operating speed as the Timer in front. Run a T on mag long enough, and you can TELL when a T on mag is running "retarded", "In time", or "Advanced time"... not from the timer, but the magnets.
Ready for the mind blower? Modern day ignition - the COP systems - use something almost identical (controleld by computers, of course) to what Couzens and Wills and Ford came up with way way back when. When you think something is new and improved and amazing - open a Dykes Auto manual from the teens and 20's and be prepared to be humbled and amazed!
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Tue May 26, 2020 12:12 am
It seems a bit questionable from an engineering standpoint that Ford kept the flywheel magneto after he installed a generator and battery on the Model T in 1919. As previously mentioned, a magneto is handy for crank starting when your battery is dead, but the Model T was not like an aircraft, where multiple redundancies are important. It seems more likely that Henry Ford was simply a man who was determined not to change what worked.
The Model T never adopted a contemporary ignition system, such as a conventional magneto or a coil and breaker points type ignition system. He stuck with the trembler coils that Spider Huff had designed for his race car in 1901. Ford seemed to shy away from electrics, remarkable considering he was once head engineer for Edison Electric. Although his "stick with what works" philosophy served him well for a time, eventually it backfired when competitors surpassed his designs. The Model T, the Fordson tractor and the Ford Trimotor airliner were all gamechangers when they were introduced, but became totally obsolete a few years later. Ford's legendary stubbornness only became worse with his advancing age, and it was up to his family to step in and defy him when the company's future was at stake.
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Tue May 26, 2020 11:08 am
Lots of good comments and information in this thread. Thank you all for posting. A few points (take them for what they are worth..... 8-) )
Ed Huff collaborated with Henry Ford to design one of the most unique ignition/magneto systems ever invented. In fact, the likes of it wouldn’t be seen again on production automobiles until the late 1950’s
No, not the low tension flywheel generating magneto used on over 15 million Model T (that came later). The world’s first working CDI (capacitive discharge ignition). Ford contracted Huff to design the magneto, initially for his six cylinder racer. Work began on the racer and magneto in early 1904, with the finished product appearing in January, 1905. The magneto was then built commercially by Holley Brothers, and placed as standard equipment on Model K, and optional equipment on the Thomas Flyer 50 hp model (1906). The magneto was also standard equipment on other automobile (memory?) in 1906 and 1907.
Patent application submitted July 1905, issued to Henry Ford, March 1908:
This link to “The Holley Foundation” mentions the magneto used on “A six-cylinder car, equipped with a Holley Magneto, won a 24-hour road race without a whimper. Thus, began Holley's association with race cars that win.”
Unfortunately, the mention doesn’t include the model of six-cylinder, a Ford Model K:
http://www.theholleyfoundation.org/history_2.html
Anyway, bottom line, Henry Ford surrounded himself with several cutting edge personalities in the fledgling automotive industry. He seems to have had a knack for finding the best at what they did, and teaming up with them to produce some of the best quality and lowest priced cars of the time, culminating in the Model T.
One last point, there were both dry and “storage” or wet cell batteries available by 1906. As this excerpt from the Model K operators manual writes, both were recommended for use with the dual ignition Model K:
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Tue May 26, 2020 11:59 am
Our research may differ, but I have to question the assertion that both ignition systems could be used at the same time. The flywheel magneto is an alternating current (AC) generator, and the battery is a direct current (DC) source. Both will operate the trembler coils, creating ignition spark, but used together, the DC will demagnetize the magneto, rendering it useless until new magnets are installed. Unless I missed something, the ignition switch was designed to prevent this.
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Tue May 26, 2020 12:05 pm
Greg,
I’m referring to Ford’s first magneto and dual ignition system, standard to the Ford six (Model K).
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Tue May 26, 2020 2:20 pm
It's my understanding that in the early days of the Model T, a standard magneto cost $150. Completely out of range for a car that sold for a few hundred dollars.
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Tue May 26, 2020 4:07 pm
I believe if a little research is in order, one would discover that a Bosch Magneto, retail was $30.00 (in 1916) new. A manufacture would have paid less order in bulk. See Automobile Dealer and Repairer
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Wed May 27, 2020 11:11 am
I believe that my source, the Ford Museum archive, was referring to 1908, when the first Model T was released. It said that at that time, the only available magneto cost nearly $150. I'm sure that they became cheaper in subsequent years, and plenty of owners were retrofitting them to their cars. But Henry Ford, always committed to staying with what worked, never saw fit to install them as standard equipment on the Model T.
Last Name: House
MTFCA Number: 115
Post by George House » Wed May 27, 2020 11:49 am
The biggest puzzler I’ve ever recognized to Henry Ford’s way of thinking is his introduction of 3 speed sliding gear transmissions in 1917 with his Fordson tractors and continuing throughout Model T 2 speed planetary transmission production in his cars.
One of the biggest problems with today’s youth is they’ve never known the fear of hearing leather being rapidly pulled through seven Wrangler belt loops.
Post by Mark Gregush » Wed May 27, 2020 12:42 pm
As far as charging a battery goes, before rural areas got electricity, there were windmill or gas engine powered generators that could charge batteries. How else could you listen to the battery powered radio! ;) No lights in the house but we got a telephone!
1920 Dodge touring
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Wed May 27, 2020 2:31 pm
Farmers were resourceful, and would have found a way to pull-start the car with a tractor or horses, or parked on a hill.
Harry Lillo
First Name: Harry
Last Name: Lillo
MTFCA Number: 13996
Post by Harry Lillo » Wed May 27, 2020 8:19 pm
Mark, people listened to their radio using two dry cell batteries; an A and a B cell.
The A cell was a low voltage battery with six to twelve volts.
The B cell was the high voltage being from 22.5 to 135 volts.
Later on some of these radios used different dry cell voltage configurations.
The "light socket radios" came in around 1926 but manufactures continued to sell "farm radios " into the 1960's for those of us without AC electricity.
Been Here Before
Last Name: Drobnock
Post by Been Here Before » Thu May 28, 2020 12:42 pm
Really a 1920's farmer using a radio with battery...why not a free power crystal set to listen to WLW or KDKA?
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Thu May 28, 2020 4:39 pm
A lot of enthusiasts were experimenting with crystal radios in the early 1920s. If you had only one radio station nearby, the simplest crystal circuits were good enough. If you wanted a bit of tuning between stations, the tuning coil would give you a bit of selectivity. But it wasn't long before variable capacitors were used to make tunable tank circuits that greatly improved selectivity, and thermionic valves were used to amplify weaker stations. Loudspeakers replaced headphones. By the end of the decade, radios that could pull in stations from coast to coast and from all over the globe on shortwave, were becoming popular and commercially available.
Like the computer revolution, the learning curve was steep at first, but before long, anyone could use one one without any special skills at all.
