Source for Hard-to-Find Fasteners
Topic author - Posts: 26
- Last Name: Neal
- * REQUIRED* Type and Year of Model Ts owned: 1925 Roadster Pickup
Hi folks,
I’ve found a great source for hard-to-find bolts and screws, both in steel or brass. Best of all, no minimum quantities when ordering. Quality is better than that sold at the big box stores. Plus, they ship fast, too.
http://www.Boltdepot.com
I am not associated with them in any way, just a happy customer.
John
John
John Neal
Virginia
‘25 Roadster Pickup
Virginia
‘25 Roadster Pickup
- First Name: Bob
- Last Name: Coiro
- Board Member Since: 2009
Re: Source for Hard-to-Find Fasteners
Excellent! Thank you.
- First Name: Chad
- Last Name: Azevedo
- * REQUIRED* Type and Year of Model Ts owned: 1926 Boattail speedster, 1912 Tourabout project, 1927 Speedster (build)
You got my hopes up but I guess I'll just have to keep looking
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Been using them for many years, very satisfied.
- First Name: Joe
- Last Name: Lucas
- MTFCA Number: 50498
What a great resource. Even have elevator bolts that I need right now.
Many thanks for this link, John
None of us is as smart as all of us.
- First Name: Chris
- Last Name: Rini
- * REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Awesome!
How are their wood screws? Do they have cut threads like vintage ones?
- Last Name: Barclay
- * REQUIRED* Type and Year of Model Ts owned: 1920 coupe
When John first posted this it reminded me that I needed some straight slot screws, so I ordered a bag of 100. I think the quality looks good but I don't know how the threads are made. They look like they are cut to me, tried to get a picture maybe you can tell from the picture. George
NH Full Flow Float Valves
George, what you show is a self tapping screw used in metalwork. Wood screws will have a tapered thread for its length and there will be some plain shank. Once installed, the appearance will be the same.
I started out to disagree with you, but conclude that you are correct. In George's defense, though, the screw he posted is very commonly sold as a wood screw in the US.
- MTFCA Number: 121
- MTFCI Number: 16310
I've had good luck with Blacksmith Bolt in Portland, Oregon.
Scott, in the interests of accuracy, I found a box of such screws in the stuff I just loaded for the Bendigo swap meet. They are labeled as chipboard screws!
My theory is that tapered wood screws would tend to work out of chipboard, but parallel threaded screwd would maintain their hold.
While chipboard is made of wood derivatives, the screws are still self tapping.
Learned something else today
- First Name: Chad
What I would like is a nice slotted fillister head that has a portion not threaded in an 8-32, 10-32, and 12-32 but that is impossible to find
- First Name: R.V.
- Last Name: Anderson
Chad, I can help you with the #8s. How many do you want?
- First Name: Rich
- Last Name: Bingham
The wood screw we have known for decades is tapered, and depending on the application (wood species, etc. ) they operate as a wedge, often failing because they split wood. "Sheet metal" screws being parallel threaded have proven (for me) to be more reliable in situations where a project sees a lot of weather. That's neither here nor there when we want fasteners that are "period correct" in their look. Personally, I have a phobia for Philips-head fasteners, and even "regular" machine bolts and nuts look very different nowadays from the old stuff. Heads were heftier, nuts more generous. They're just overall more pleasing to handle and work with.
"Get a horse !"
you're probably aware, but will tell you anyway: there are drill bit/countersinks that drill the correct hole for wood screws and the wood doesn't split. I have some and use them for any project requiring a wood screw...they're tapered drills...pretty clever.
Here's an example of them: https://www.mscdirect.com/browse/tnpla/ ... n0EALw_wcB
- MTFCA Number: 16175
- MTFCI Number: 14758
Why with a portion not threaded? Where are they used?What I would like is a nice slotted fillister head that has a portion not threaded in an 8-32, 10-32, and 12-32...
Chad
http://www.accuratescrew.com/catalog/fillister-head
Steve
they are used when you want a captured fastener
Steve
- First Name: Chad
I find them used all over. My particular purpose requires that the un threaded portion be the diameter of the threaded portion so what was posted will not work.
