Do I need a bearing here?
Mustang1964s
Topic author - Posts: 272
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
I am rebuilding the steering column for the '27.
The column is in primer.
Is there a bearing that need to be in the bottom of the column?
Re: Do I need a bearing here?
No!
There is a bushing to replace at the lower frame bracket for that steering shaft.
Once you drive out the old one, drive in the new.
Then ream that new bushing to size.
- First Name: Henry
- Last Name: Lee
Nice work Dan!!!!!
Barth_Tool_Co
- First Name: Jason
- Last Name: Alvord
- * REQUIRED* Type and Year of Model Ts owned: '26 Touring
Dan, what brand of adjustable reamer are you using there?
... and my number is Beechwood 4-5789
1926 Touring - "Corrina"
Jason
Just a no-name brand from the local tool supply.
Any good 3/4" adjustable reamer should work. The reamer shown
is this 23/32" to 25/32" or 3/4" size. It was marked on the shaft "INDIA"
Dan
Dan
