Ring gear and pinion
Posted: Wed Nov 13, 2019 10:35 am
by Haroldc30
Hello everyone. Thanking about changing my pinion gear.I've got a 11tooth pinion and a 40 tooth ring gear can I use a 10 tooth pinion on the 40 tooth ring gear. Thanks in advance Harold
Re: Ring gear and pinion
Posted: Wed Nov 13, 2019 10:43 am
by TonyB
Yes.
I did quite successfully on the Town Car. It required a little more effort than an 11 tooth pinion but just a few shims.
Posted: Fri Nov 15, 2019 1:02 am
by Aarongriffey
I built a speedster with a Warford aluminum three speed and a 10 tooth pinion.
The 10 tooth was made to run against the stock ring gear.
The gout to one rear end gives you plenty of power in direct Warford or high Ruxtell.
But....if going up a slight upgrade if you run in high Ruckstell or direct Warford the motor is running very fast to tour with stock T’s.
If you run in overdrive Warford the engine will overheat from running too slow and lugging.
If you run in underdrive Warford or low Ruckstell everybody with the stock setup will overheat because their engines will be running too slow.
We found I just could not lead tours with that setup. The 3:63 overall gear ratio is by far the best in hilly country.
Posted: Fri Nov 15, 2019 10:38 am
Unless you do a lot of driving on mountain roads, I would suggest sticking with the stock ratio.
Posted: Fri Nov 15, 2019 10:48 am
Changing the differential gears from original has shown to be questionable after years of reading different outcomes on the forum. More than a few have noted that overall leaving the original gear ratio is the best way to go. Different opinions on this will always arise.
Posted: Fri Nov 15, 2019 11:16 am
by Joe Bell
If you are pulling hills all the time the ten tooth is great but if you are flat lands I would run the eleven tooth.
