Question about new tool??
Topic author - Posts: 4101
- Last Name: Hatch
- MTFCA Number: 49974
I am think about making a run of 13/32 x 16 taps. I will need to know if there is any interest in these taps? Post here or email me at address in pictures. Thanks Dan
- Attachments
- 49A19A64-D93C-48EE-B3D7-AC782737131B.jpeg (50.1 KiB) Viewed 8719 times
- First Name: Charlie
- Last Name: Gagel
- * REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),15 Touring,22Touring,22 TT,21 Fire Truck,14 Chief Car
- MTFCA Number: 8377
- MTFCI Number: 22437
Re: Question about new tool??
Where were these threads used?
- MTFCA Number: 4838
- MTFCI Number: 115
Rear axle clam shell, for the drive shaft roller bearing housing holes. Use the tap to clean the holes for the studs or the later cap screws.
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
- MTFCA Number: 50618
I’ll take one.
Brad
Brad
- Last Name: Hatch
Needing at least 12 orders before I can get info. Dan
- First Name: Val
- Last Name: Soupios
I'll also take one.
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
- MTFCA Number: 27211
I will take one too !
- First Name: Dale
- Last Name: Kemmerer
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
I will take one also. Dale
- First Name: Gary
- Last Name: Bausch
- * REQUIRED* Type and Year of Model Ts owned: 1925 Speedster, 1923 TT w/Fabco frame conversion
I will take one also Dan. Gary Bausch
- First Name: Clyde
- Last Name: Gibson
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor Sedan, 1926 Roadster
- MTFCA Number: 32266
- First Name: Clyde
- Last Name: Gibson
I will take one also. Clyde Gibson
- First Name: Ken
- Last Name: Buhler
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster 1927 Coupe
- MTFCA Number: 49471
- Board Member Since: 2012
I also. Ken Buhler
Work honestly
Stay true to your word
Get the job done right
- First Name: Hal
- Last Name: Schedler
- * REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
- MTFCA Number: 16688
- MTFCI Number: 19356
I'll take one also. It would be nice to get a ball-park on $$
- Last Name: Hatch
This only to find out if there is interest in making them. If there is enough interest I will see what the cost will be. I will let you know price before I make them so I will know if you want one. I will get back as soon as I know price. Thanks Dan
- First Name: Bill
- Last Name: Anziani
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
I would be interested as well
- Last Name: bevardos
- * REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
me too....
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
Also if you have taste to do a tap for petcock it will be nice too.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- Last Name: Bartsch
- MTFCA Number: 30615
Dan I am interested if the price is under $20. jab35<at>cornell(dot)edu Thanks for making the offer, jb
- MTFCI Number: 115
Mario
A tap for the petcock thread in the crankcase or radiator lower tank is a simple 1/8" NPT (National Pipe Thread) -USA, 4-flute tap. In the US, a $3-6 common item, inexpensive.
Caution to not tap too deep at all, use care. This tap is taper thread, like modern pipe threads are, to allow a petcock to seat and seal. But Ford crankcase and old radiator petcock holes threads are just a tad different than modern, if you tap too hard, the taper threads can enlarge and the petcock might seep. Many old crankcase petcock holes have been compromised with modern taps.
- Last Name: Hatch
I do not have a price yet, but you can be sure it will not be under $20.00. Dan
- First Name: Mario
Thank you Dan for the advice. Really appreciated it
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- Last Name: Clements
- MTFCA Number: 49592
Wouldn't that make the correct pipe tap a 1/8" x 27 NPS tap and not a NPT tap? NPT is tapered while NPS is straight threads. NPS taps are readily available.
I would be interested in a 13/32" X 16 tap also.
- First Name: Danny
- Last Name: Deaton
I would be in for one
- First Name: Jeff
- Last Name: Lee
Hi Dan
I'd be interested in one too, if you are OK with mailing to Canada.
Jeff
Nova Scotia
Jeff
Nova Scotia
- First Name: Tom
- Last Name: Leroux
- MTFCA Number: 20412
- Board Member Since: 2010
I will also take one
tom leroux
tom leroux
- First Name: Ken
- Last Name: Buhler
James,
We can't tell the supplier what they should sell it for. I think that if you can't afford the part, do without unless you can provide a better part for less. We need to turn this hobby from cheap to fair.
Ken Buhler
Work honestly
- First Name: Philip
- Last Name: Lawrence
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1916 Runabout, 1920 Touring
- MTFCA Number: 5591
- MTFCI Number: 25062
- Board Member Since: 2014
Dan, I would be interested in one also.
- Last Name: Hatch
Working on price. Will let you know what I come up with. Thanks Dan
- First Name: Eric
- Last Name: Dysart
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1916 Touring, 1927 Runabout
It doesn’t appear that James was suggesting what the price should be, but merely what he would be willing to pay. Since no indication of price had been mentioned, I think that his comment was appropriate.Ken Buhler wrote: ↑Thu Nov 21, 2019 1:10 amJames,
Ken Buhler
Keep crankin’
Eric
- MTFCA Number: 52564
The petcocks are pipe thread not straight thread. Sorry for thread drift.
1920 Dodge touring
1920 Dodge touring
