Question about new tool??
Posted: Thu Nov 14, 2019 11:14 am
by Dan Hatch
I am think about making a run of 13/32 x 16 taps. I will need to know if there is any interest in these taps? Post here or email me at address in pictures. Thanks Dan
Re: Question about new tool??
Posted: Thu Nov 14, 2019 11:49 am
by Fire_chief
Where were these threads used?
Posted: Thu Nov 14, 2019 11:55 am
Rear axle clam shell, for the drive shaft roller bearing housing holes. Use the tap to clean the holes for the studs or the later cap screws.
Posted: Thu Nov 14, 2019 12:47 pm
by Jeepbone1
I’ll take one.
Brad
Posted: Thu Nov 14, 2019 3:52 pm
by Dan Hatch
Needing at least 12 orders before I can get info. Dan
Posted: Thu Nov 14, 2019 4:03 pm
by Russ T Fender
I'll also take one.
Posted: Thu Nov 14, 2019 4:23 pm
by sweet23
I will take one too !
Posted: Thu Nov 14, 2019 4:46 pm
by pre15dale
I will take one also. Dale
Posted: Thu Nov 14, 2019 10:03 pm
by reolds
I will take one also Dan. Gary Bausch
Posted: Thu Nov 14, 2019 10:15 pm
by Graybeard77
Posted: Thu Nov 14, 2019 10:16 pm
by Graybeard77
I will take one also. Clyde Gibson
Posted: Fri Nov 15, 2019 12:37 am
by Ken Buhler
I also. Ken Buhler
Posted: Fri Nov 15, 2019 1:36 am
by HalSched
I'll take one also. It would be nice to get a ball-park on $$
Posted: Fri Nov 15, 2019 6:28 am
by Dan Hatch
This only to find out if there is interest in making them. If there is enough interest I will see what the cost will be. I will let you know price before I make them so I will know if you want one. I will get back as soon as I know price. Thanks Dan
Posted: Fri Nov 15, 2019 6:41 am
by Bill Anziani
I would be interested as well
Posted: Fri Nov 15, 2019 9:24 am
by John bevardos
me too....
Posted: Fri Nov 15, 2019 9:28 am
by Quickm007
Posted: Fri Nov 15, 2019 9:29 am
by Quickm007
Also if you have taste to do a tap for petcock it will be nice too.
Posted: Fri Nov 15, 2019 11:13 am
by jab35
Dan I am interested if the price is under $20. jab35<at>cornell(dot)edu Thanks for making the offer, jb
Posted: Fri Nov 15, 2019 11:22 am
Mario
A tap for the petcock thread in the crankcase or radiator lower tank is a simple 1/8" NPT (National Pipe Thread) -USA, 4-flute tap. In the US, a $3-6 common item, inexpensive.
Caution to not tap too deep at all, use care. This tap is taper thread, like modern pipe threads are, to allow a petcock to seat and seal. But Ford crankcase and old radiator petcock holes threads are just a tad different than modern, if you tap too hard, the taper threads can enlarge and the petcock might seep. Many old crankcase petcock holes have been compromised with modern taps.
Posted: Fri Nov 15, 2019 11:28 am
by Dan Hatch
I do not have a price yet, but you can be sure it will not be under $20.00. Dan
Posted: Sat Nov 16, 2019 10:18 am
by Quickm007
Thank you Dan for the advice. Really appreciated it
Posted: Sat Nov 16, 2019 11:33 am
by Scott C.
Wouldn't that make the correct pipe tap a 1/8" x 27 NPS tap and not a NPT tap? NPT is tapered while NPS is straight threads. NPS taps are readily available.
I would be interested in a 13/32" X 16 tap also.
Posted: Sat Nov 16, 2019 1:52 pm
by dmdeaton
I would be in for one
Posted: Sun Nov 17, 2019 11:17 am
by pre15dale
Bump
Posted: Sun Nov 17, 2019 7:08 pm
by nsbrassnut
Hi Dan
I'd be interested in one too, if you are OK with mailing to Canada.
Jeff
Nova Scotia
Posted: Sun Nov 17, 2019 9:18 pm
by TLeroux
I will also take one
tom leroux
Posted: Thu Nov 21, 2019 1:10 am
by Ken Buhler
jab35 wrote: ↑Fri Nov 15, 2019 11:13 am
James,
We can't tell the supplier what they should sell it for. I think that if you can't afford the part, do without unless you can provide a better part for less. We need to turn this hobby from cheap to fair.
Ken Buhler
Posted: Thu Nov 21, 2019 8:19 am
by Philip Lawrence
Dan, I would be interested in one also.
Posted: Thu Nov 21, 2019 10:55 am
by Dan Hatch
Working on price. Will let you know what I come up with. Thanks Dan
Posted: Thu Nov 21, 2019 11:00 am
by ewdysar
Ken Buhler wrote: ↑Thu Nov 21, 2019 1:10 am
James,
Ken Buhler
It doesn’t appear that James was suggesting what the price should be, but merely what he would be willing to pay. Since no indication of price had been mentioned, I think that his comment was appropriate.
Keep crankin’
Eric
Posted: Thu Nov 21, 2019 11:04 am
The petcocks are pipe thread not straight thread. Sorry for thread drift.
