Ring gear bolts
Posted: Mon Nov 18, 2019 6:56 pm
by Don ellis
In the past I have had to trim ring gear bolts to keep them from hitting the pinion. This one is very close. Is this a common thing or have I got something wrong?
Re: Ring gear bolts
Posted: Mon Nov 18, 2019 7:11 pm
by Henry K. Lee
Don,
If using older/used gear sets, this is more common but have had it happen on new as well. Two options, use a very fine SAE displacement washer under the 10 attachment bolts, or install a 5/16" fine thread nut down on the threads and sand/grind down the threads on the bolts to achieve the required length.
Hope this Helps,
Re: Ring gear bolts
Posted: Mon Nov 18, 2019 7:13 pm
by Henry K. Lee
That almost looks like it has an insert in the photo. Does it?
Re: Ring gear bolts
Posted: Mon Nov 18, 2019 7:16 pm
by Don ellis
It’s all new, ring gear, pinion, bolts and ruxtel.
Re: Ring gear bolts
Posted: Mon Nov 18, 2019 7:24 pm
Don, it's not an uncommon occurrence. You only need to shorten the odd bolt which causes the interference. The others can be left as is.
Re: Ring gear bolts
Posted: Mon Nov 18, 2019 9:32 pm
by Don ellis
That’s what I did, kinda just wanted to make sure it wasn’t just me. Thanks
Re: Ring gear bolts
Posted: Tue Nov 19, 2019 1:35 pm
by RGould1910
Why are the bolt heads on the tooth side of the ring gear?
Re: Ring gear bolts
Posted: Tue Nov 19, 2019 1:36 pm
by RGould1910
I see it now. Hard to see the threads from the photo
