TT Differential w/Ruckstell - Are There Felt Seals?
Posted: Thu Nov 21, 2019 8:50 am
My Dad and me are restoring a 1923 TT dump truck. The flange for the spring perch on the Ruckstell side had snapped off and we're replacing that entire side of the differential housing. There's a felt seal on the Ford side of the differential but there appears to be no seal on the Ruckstell side. I'm referring to the felt seals on the inner side of the axle tubes. Can anyone confirm if the Ruckstell side should have some sort of seal to keep oil from getting into the axle tube?
Thank you.
Thank you.
