Pick up HCCT in Roseville Ca I live in Nampa Id
havnfun
First Name: Joe
Last Name: Kowalczyk
MTFCA Number: 49558
Post by havnfun » Thu Nov 21, 2019 11:38 am
Hi anyone coming from California going through Roseville Ca and heading east through Idaho? I would like to arrange pickup of a HCCT, I can meet with you on the road, depending your route
Best Regards,
Joe
Regards,
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Board Member Since: 2008
What is an HCCT ?
Post by FreighTer Jim » Thu Nov 21, 2019 2:07 pm
What is an HCCT ?
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
First Name: Jeff
Last Name: Humble
* REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
MTFCA Number: 28034
Board Member Since: 2006
Re: Pick up HCCT in Roseville Ca I live in Nampa Id
Post by Humblej » Thu Nov 21, 2019 2:31 pm
Hand crank coil tester.
BHarper
First Name: Bill
Last Name: Harper
* REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
MTFCA Number: 5414
Post by BHarper » Thu Nov 21, 2019 3:39 pm
For Jim and others who have not been up close and personal with a Hand Cranked Coil Tester, they are heavy, top heavy, and unwieldy things. While there are several different styles regarding meter(s) and location of the coil receptacle, they all weigh about 100 pounds.
They are a challenge to pick up because the largest part to grab is the flywheel with its magnets and that turns. If you get your fingers pinched between the slowly rotating flywheel and the coil ring as the heavy beast swings when you pick it up, you yelp and drop it. It falls to the floor landing on one of your feet, breaking toes while the HCCT itself breaks. You hop around on one foot, trip over the now smashed HCCT and fall to the floor.
As I recall, when Ron Patterson would sell one, he would not ship it and required that you pick it up or make arrangements for some sort of "bucket brigade" to get it to you. I'm guessing that Joe is attempting to do this. So, can we help him out? I'm a bit out of the way.
havnfun
First Name: Joe
MTFCA Number: 49558
Post by havnfun » Thu Nov 21, 2019 7:53 pm
Bill is correct, I'm trying to arrange direct Pickup and transportation as the current owner will not ship. I haven't purchased it as yet, trying to resolve transportation prior to agreeing to purchase.
Thanks in advance
Regards,
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Post by Burger in Spokane » Thu Nov 21, 2019 10:33 pm
They break down to more manageable parts pretty easily, and with much
less risk for damage when handling/shipping.
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Fri Nov 22, 2019 1:03 am
I fully understand not wanting to ship. I did however did at one time suggest to remove the flywheel/magnets and coil ring to someone. They are off the shelf parts and I think some were sold that way.
1920 Dodge touring
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Mr. Harper knows me all to well
Post by FreighTer Jim » Fri Nov 22, 2019 11:45 am
Alright Bill ..., 😉
Just can I did that the one time ... 👀
Well - I guess twice .... 😔
OK - but that third time .... 😫
FJ
havnfun
First Name: Joe
MTFCA Number: 49558
Post by havnfun » Sat Nov 23, 2019 1:45 pm
Thnx everyone, the Issue is resolved,
Mark,
Thanks for the idea of disassembling, the seller was able to remove the flywheel, coil ring and magnets, going to ship it in several boxes, the flywheel I have several on hand
Regards,
Ron Patterson
First Name: Ronald
Last Name: Patterson
Post by Ron Patterson » Sat Nov 23, 2019 1:57 pm
Joe
Be sure the AC Ammeter is removed and carefully packed in a high density Styrofoam padded box for shipping!!
The meter is the most costly part of a HCCT to replace if damaged and the easiest part to damage if not very carefully handled.
Ron Patterson
havnfun
First Name: Joe
MTFCA Number: 49558
Post by havnfun » Sat Nov 23, 2019 6:23 pm
Ron,
Thanks for your input, I passed it along to the seller
Regards,
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Sun Nov 24, 2019 6:18 pm
Great! While you are waiting for it you could get the magnets charged and doctor up a coil ring. :D
1920 Dodge touring
