Authentic Top Trim Pieces
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Mon Nov 25, 2019 10:01 pm
Am thinking about rebuilding the top on my ‘23 runabout. I have these pieces that were used to finish the ends of hidem welt. The top one was near the arm rest. Thinking one in the middle is model A rather than T. The bottom one was on the top trim.
TonyB
First Name: Tony
Last Name: Bowker
MTFCA Number: 32
Re: Authentic Top Trim Pieces
Post by TonyB » Mon Nov 25, 2019 10:06 pm
I have seen the style on the second picture on what I believe to be fairly original cars.
I don’t know a modern source.
Tony Bowker
La Mesa, California
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Tue Nov 26, 2019 10:00 am
Here is some info from an older thread:
http://www.mtfca.com/discus/messages/11 ... 1284814659
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Tue Nov 26, 2019 10:37 am
You have a lot of priming and sanding to do on that top one, I've done it, and to me it's worth it for a non obtainable part. It would be nice for someone that does stamping to be able to remake that part. If there is someone out there that can do it, I have a NOS spear to loan.
TonyB
First Name: Tony
Last Name: Bowker
MTFCA Number: 32
Post by TonyB » Tue Nov 26, 2019 10:55 am
A friend contacted me with pictures of trim ends available from Macs. One looks very similar to the one I have previously seen on Ts.
Trim end from Macs
Trim end from Macs
Apparently Macs has several other styles in their catalog.
Tony Bowker
La Mesa, California
Jim, Sr.
First Name: Jim, Sr.
Last Name: Rodell
* REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
MTFCA Number: 2406
MTFCI Number: 22213
Post by Jim, Sr. » Tue Nov 26, 2019 8:56 pm
These are photos of an original 1924 touring.
1922 Coupe , 1926 Touring
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Tue Nov 26, 2019 9:36 pm
Thanks Jim for posting. I can always rely on you to post important information with no guessing allowed!!
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Tue Nov 26, 2019 11:12 pm
Ok guys. So, it appears that I’m missing one of these. Anyone have one to spare that is as crappy as mine? 😀
Dropacent
Last Name: Morsher
Post by Dropacent » Wed Nov 27, 2019 10:30 pm
I have just one, a couple shades better. It’ll be in the mail. T
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Thu Nov 28, 2019 11:25 am
Mark: When you get mine, you'll have an extra! Happy Thanksgiving!
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Thu Nov 28, 2019 2:46 pm
So, I would like a little more edjumacashion about these end pieces...
1) Is the end for the top the pointed end and the end for the armrest square the end?
2) Is the arrow-head shaped piece (finger pointing #1) the same as the rusty ends (#4 & #5 from the left) but the notches out of the corners?
2b) Could a #1 be made from a #4 or #5?
3) Was the non-notched type used? If so, when?
I presume these would only been used with the hide 'em welt used from about 1923-1925?
Keith
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Thu Nov 28, 2019 3:08 pm
Thanks Tim!
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Fri Nov 29, 2019 2:52 am
It looks to me like some of those that Tim posted could be made to look very close to an original with a bit of time and a Dremel with a cutoff wheel. Dave
1925 mostly original coupe.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Fri Nov 29, 2019 11:26 am
The problem with converting a common style spear to the Ford style is the Ford style is bigger. Yes, you can alter a common one to have the tails like a Ford one, but it still will not be correct. The Ford spear is wider from top to bottom.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sat Nov 30, 2019 9:23 pm
The spears posted above as far as I know were only used by Ford. They can't be made from anything. If someone with a metal stamping business would be willing to make a die to stamp these, I'm sure it would be a big seller for the purists.
