Authentic Top Trim Pieces
Posted: Mon Nov 25, 2019 10:01 pm
by Mark Osterman
Am thinking about rebuilding the top on my ‘23 runabout. I have these pieces that were used to finish the ends of hidem welt. The top one was near the arm rest. Thinking one in the middle is model A rather than T. The bottom one was on the top trim.
Re: Authentic Top Trim Pieces
Posted: Mon Nov 25, 2019 10:06 pm
by TonyB
I have seen the style on the second picture on what I believe to be fairly original cars.
I don’t know a modern source.
Posted: Tue Nov 26, 2019 10:00 am
by CudaMan
Here is some info from an older thread:
http://www.mtfca.com/discus/messages/11 ... 1284814659
Posted: Tue Nov 26, 2019 10:37 am
by Original Smith
You have a lot of priming and sanding to do on that top one, I've done it, and to me it's worth it for a non obtainable part. It would be nice for someone that does stamping to be able to remake that part. If there is someone out there that can do it, I have a NOS spear to loan.
Posted: Tue Nov 26, 2019 10:55 am
by TonyB
A friend contacted me with pictures of trim ends available from Macs. One looks very similar to the one I have previously seen on Ts.
Trim end from Macs
Trim end from Macs
Apparently Macs has several other styles in their catalog.
Posted: Tue Nov 26, 2019 8:56 pm
by Jim, Sr.
These are photos of an original 1924 touring.
Posted: Tue Nov 26, 2019 9:36 pm
by Original Smith
Thanks Jim for posting. I can always rely on you to post important information with no guessing allowed!!
Posted: Tue Nov 26, 2019 11:12 pm
by Mark Osterman
Ok guys. So, it appears that I’m missing one of these. Anyone have one to spare that is as crappy as mine? 😀
Posted: Wed Nov 27, 2019 10:30 pm
by Dropacent
I have just one, a couple shades better. It’ll be in the mail. T
Posted: Thu Nov 28, 2019 11:25 am
by Original Smith
Mark: When you get mine, you'll have an extra! Happy Thanksgiving!
Posted: Thu Nov 28, 2019 2:46 pm
by KWTownsend
So, I would like a little more edjumacashion about these end pieces...
1) Is the end for the top the pointed end and the end for the armrest square the end?
2) Is the arrow-head shaped piece (finger pointing #1) the same as the rusty ends (#4 & #5 from the left) but the notches out of the corners?
2b) Could a #1 be made from a #4 or #5?
3) Was the non-notched type used? If so, when?
I presume these would only been used with the hide 'em welt used from about 1923-1925?
Keith
Posted: Thu Nov 28, 2019 3:08 pm
by Mark Osterman
Thanks Tim!
Posted: Fri Nov 29, 2019 2:52 am
by D Stroud
It looks to me like some of those that Tim posted could be made to look very close to an original with a bit of time and a Dremel with a cutoff wheel. Dave
Posted: Fri Nov 29, 2019 11:26 am
by Original Smith
The problem with converting a common style spear to the Ford style is the Ford style is bigger. Yes, you can alter a common one to have the tails like a Ford one, but it still will not be correct. The Ford spear is wider from top to bottom.
Posted: Sat Nov 30, 2019 9:23 pm
by Original Smith
The spears posted above as far as I know were only used by Ford. They can't be made from anything. If someone with a metal stamping business would be willing to make a die to stamp these, I'm sure it would be a big seller for the purists.
