21" tires for a driver
blgitn
First Name: Roger
Last Name: Harmon
MTFCA Number: 16412
Post by blgitn » Sun Dec 01, 2019 9:56 pm
Which are more highly recommend, Lucas (from Snyder's) or Universal brand?
MTFCA Number: 4838
MTFCI Number: 115
Re: 21" tires for a driver
Post by DanTreace » Sun Dec 01, 2019 10:09 pm
Just installed a set of the lower cost Universal 4.50/4.75 x 21" on my touring. Like the tread pattern, and edge, they ride nice too. Nothing like new tires....the old ones were 12 years old harder rubber ;)
Last Name: Gregush
Post by Mark Gregush » Sun Dec 01, 2019 11:47 pm
Check on line, you might find better prices.
https://www.lucasclassictires.com/21-Tires_c46.htm
If you look sometimes you can find free shipping. I am not recommending any particular brand, all my tires are used, some almost new but older.
1921 Huckster
ewdysar
First Name: Eric
Last Name: Dysart
Post by ewdysar » Mon Dec 02, 2019 2:11 am
just until tomorrow...
https://www.mtfca.com/phpBB3/viewtopic.php?f=16&t=8755
Coker tires Black Friday special.
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Mon Dec 02, 2019 10:47 am
The Universal 4.50-4.75x21 tires are the cheapest, and slightly fatter than the “stock” tire. Universal has free shipping on everything thru this afternoon. Its a once-per-year deal they only do on the four days after Thanksgiving. Free shipping should save you an additional $80 or more.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Mon Dec 02, 2019 10:54 am
Clincher tires are famously all made in the same factory and vary only by name, tread pattern, and price, with no variation in quality. How about 21" tires? Does the same hold true for them?
Dennis Prince
Last Name: Prince
MTFCA Number: 22802
Post by Dennis Prince » Mon Dec 02, 2019 11:17 am
If you hate changing tires as much as I do, I would step up and get Firestones. They will last a whole lot longer, also don't forget to check you toe in when you put the new tires on.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Mon Dec 02, 2019 11:55 am
Steve - most but not all 21" 's are U.S. made.
Bmettli
First Name: Brian
Last Name: Mettling
Post by Bmettli » Mon Dec 02, 2019 8:47 pm
I’ve had those Lucas 21s on my T for about 7 years now. I like em. Only compliant is that they turn brown after a few hours of UV exposure outside. I thought they were all made in Vietnam though, not USA
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Mon Dec 02, 2019 9:32 pm
Lucas 21" are imported - 21" Firestone, Goodyear, Goodrich & some others are made in the U.S.A.
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Wed Dec 04, 2019 2:07 am
I bought a set of five (5) 21” Universal tires for my 1926 Coupe, 48 years ago in 1971. While the treads are worn, the rubber is still good and handle the car nicely and I would highly recommend Universal tires, however, because of the close friendship between Henry Ford and Harvey Firestone and their historical link, 2 years ago, I bought a new set of five 21” Firestone tires from Snyder’s, but haven’t gotten around to mounting them yet. Jim Patrick
George Hand
Last Name: Hand
MTFCA Number: 28114
MTFCI Number: 21834
Post by George Hand » Wed Dec 04, 2019 3:39 am
I bought new Universal 21"s this spring and they were made in Vietnam.
dlmyers
First Name: Dale
Last Name: Myers
MTFCA Number: 24465
MTFCI Number: 19884
Post by dlmyers » Wed Dec 04, 2019 8:59 am
Here is a link to an earlier discussion about 21" tires.
http://www.mtfca.com/discus/messages/708324/722284.html
The old forums are a gold mine of information.
rnkugel
First Name: Reuben
Last Name: Kugel
MTFCA Number: 49871
MTFCI Number: 24323
Post by rnkugel » Wed Dec 04, 2019 10:02 am
Whatever tires you decide to buy, check out Summit Racing. All orders over $100 is free shipping all the time. Yes they do carry a number of tires for Ts. Got two sets of Universals (plus flaps and tubes) from them the last couple of years.
1915 Touring
1926 RAJO Speedster
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Wed Dec 04, 2019 11:35 am
If Summit's website lists any Model T tires, it's designed to keep them well hidden. I entered Model T Ford for 1915 and 1926, and got several pages, mostly showing car covers.
Scott C.
Last Name: Clements
MTFCA Number: 49592
Post by Scott C. » Wed Dec 04, 2019 11:44 am
Steve, Search for tube by size, then options will appear for tires. That is how I found them.
Post by Scott_Conger » Wed Dec 04, 2019 11:46 am
Steve
indeed they are, but they're there:
https://www.summitracing.com/search/bra ... =Ascending
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Wed Dec 04, 2019 12:03 pm
"The best way is always the simplest. The attics of the world are cluttered up with complicated failures. Henry Ford
Don’t find fault, find a remedy; anybody can complain. Henry Ford"
Very true, Dan. William of Ockham (1285-1347/49) stated a principle referred to as Ockham's Razor that, in modern terms, says all things equal the simple answer is usually the right answer. It's still true!
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Wed Dec 04, 2019 1:21 pm
So Summit has at least one tire for Model T. Its the same price as Coker's, so Summit's free shipping makes it a good deal.
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Wed Dec 04, 2019 1:21 pm
That's where I bought mine. I lucked out and just happened to look them up when they were having a 10% off sale on tires. That, added to their free shipping on orders over $100, made it a nice deal.
1924 Touring
George Hand
Last Name: Hand
MTFCA Number: 28114
MTFCI Number: 21834
Post by George Hand » Wed Dec 04, 2019 3:06 pm
Coker site shows several 21" tires, the least expensive listed is Coker Universal Economy Model A Tires 78705 at $112.00 each, look up 21" for a Model A, many reply's here addressed referenced 30" Cinchers
Moxie26
Last Name: Jablonski
MTFCA Number: 407
Post by Moxie26 » Wed Dec 11, 2019 2:36 pm
I am more than pleased with the 21" Lester's I just put on my car. The tread is siped for better traction and overall gives a more comfortable ride.
